02-05-2006 05:59 PM - edited 03-03-2019 11:39 AM
I have 3 routers in the same LAN. and their IP addresses are:
R1 E0: 10.1.1.1 255.255.255.0
R2 E0: 10.1.1.2 255.255.255.0
R3 E0: 10.1.1.3 255.255.255.0
And on the R1, I configured e0:
"ip broadcast-address 10.1.1.2" and want to see what happen.
from R1 I can ping R3, but cannnot ping R2 (10.1.1.2) any more.
can someone tell me why?
by the way, what is the meaning of "ip broadcast-address 0.0.0.0"?
Solved! Go to Solution.
02-05-2006 06:35 PM
A bit more.
It does not make sense to use an address for the broadcast address that is the same as that of an actual device. So to test this, I would use something like 10.1.1.10. Then configure 'ip broadcast-address 10.1.1.10' on all three of your routers. Then, when you ping 10.1.1.10 from any of them, you should get two replies back.
Hope that helps - pls rate the post if it does.
Paresh
02-05-2006 06:24 PM
That command configures the address as the local broadcast address for the segment. The default is 255.255.255.255. (you can view this using 'sh ip int
When you set the broadcast address on R1 to be 10.1.1.2, it will be sent with an all-ones MAC address (FFFF.FFFF.FFFF) and a destination IP of 10.1.1.2. Since R2 does not recognise 10.1.1.2 as a broadcast address, it will drop that packet. Since the MAC address is a broadcast address, the IP destination address also has to be a broadcast address (RFC1009).
Some older IP implementations used to treat 0.0.0.0 as the broadcast address (not conformant with RFC1009).. setting it to 0.0.0.0 just emulates that behaviour.
Paresh
02-05-2006 06:35 PM
A bit more.
Paresh
