the meaning of the command "arp frame-relay"
att-sgcops
Just saw the 12.4 command reference, there is a command named "arp [arpa|frame-realy|snap]". And it also show us an example, which is encble frame-relay service under Ethernet:
R7(config)#int e0/0
R7(config-if)#arp frame-relay
Don't know what is the used for?
why we need to enable frame-relay service under Ethernet itnerface ?
pkhatri
Level 11
Level 11
Howdy,
That command appears to be deprecated and no one seems to be able to know what it does. There have been numerous discussions on the groupstudy mailing list regarding this and no one (so far) has been able to come up with (and prove) what that command actually does.
Here's a link to one such post:
http://www.groupstudy.com/archives/ccielab/200501/msg00214.html
Hope that helps - pls rate the post if it does.
Paresh
