the router hangs when creating subinterface with ip or removing subinterface !!!
Dr.X
Level 2
Level 2
hi ,
i have a cisco router 7206 ,
when i create subinterface with ip , the router hangs , and all interfaces are down ,
i just remove interface gi0/1 and plug it again , the problem is solved !!!!!!!
what is the relaiton between subinterfaces and hanging routers ????????
the problem occured when i configured subinterface on GI0/2  !!!!!!!
what is the reason ?????????
regards
here is my config
Gateway#sh startup-config
Using 6917 out of 2095096 bytes
upgrade fpd auto
version 12.4
service password-encryption
hostname Gateway
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret XXXXXX
no aaa new-model
ip source-route
ip wccp 80 redirect-list E1
ip wccp 90 redirect-list E2
ip cef
ip accounting-threshold 4294967295
no ipv6 cef
username TTTT password TTTTTTTT
archive
log config
hidekeys
class-map match-any WEB_SENSTIVE
match protocol http mime "text*"
match protocol http mime "image*"
match protocol http mime "application/x-javascript"
match protocol http mime "application/javascript"
match protocol http mime "application/xml"
class-map match-all ICMP
match protocol icmp
class-map match-all P2P
match protocol bittorrent
match protocol kazaa2
match protocol fasttrack
match protocol gnutella
match protocol edonkey
class-map match-all BAD_USER1
match access-group name BAD_USER1
class-map match-all BUS
match access-group name BUS
class-map match-all VIP
match access-group name VIP
class-map match-any VIDEO
match protocol http mime "video*"
class-map match-any MANAGMENT
match protocol snmp
match protocol telnet
match protocol ssh
match protocol ospf
match protocol bgp
match protocol dns
policy-map BAD_USER
class BAD_USER1
police cir 4000000 bc 125000 be 125000
conform-action transmit
exceed-action drop
violate-action drop
class WEB_SENSTIVE
bandwidth percent 40
class ICMP
priority 1000
class MANAGMENT
bandwidth percent 4
class P2P
shape average percent 1
class VIDEO
class VIP
priority 6000
class class-default
policy-map TEST
class class-default
shape average 33000000
policy-map TEST2
class class-default
interface GigabitEthernet0/1
description LAN to BRAS
bandwidth 230000
ip address 10.160.150.2 255.255.255.0
ip wccp 80 redirect in
ip policy route-map CACHE-REDIRECT
load-interval 30
duplex auto
speed auto
media-type rj45
negotiation auto
interface FastEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description Cache
bandwidth 150000
ip address XXXXXXXXXX
ip wccp redirect exclude in
load-interval 30
duplex auto
speed 1000
media-type rj45
negotiation auto
interface GigabitEthernet0/3
description Internet from XXXXXXl
bandwidth 230000
ip address XXXXX
ip wccp 90 redirect in
load-interval 30
duplex full
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/3.11
description InternetXXXXXXl
encapsulation dot1Q 11
ip address XXXXX
router bgp XXXXX
no synchronization
bgp log-neighbor-changes
network XXXX mask 255.255.254.0
network XXXX mask 255.255.255.0
network 1XXXX mask 255.255.255.128
network XXXXX mask 255.255.254.0
network XXXXX mask 255.255.252.0
network XXXX mask 255.255.252.0
network 1XXXXXXX.0 mask 255.255.252.0
redistribute connected
neighbor XXXXX remote-as XXXXX
neighbor XXXXX route-map XXXXout
neighbor XXXX remote-as XXX
neighbor XXXX route-map XXX out
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXXX
ip route XXXXXX 255.255.254.0 10.160.150.1
ip route XXXX 255.255.255.128 10.160.150.1
ip route XXXXX 255.255.254.0 10.160.150.1
ip route XXXX 255.255.252.0 10.160.150.1
ip route XXXXX 255.255.252.0 10.160.150.1
ip route XXXXX0 255.255.252.0 10.160.150.1
no ip http server
no ip http secure-server
ip access-list extended BAD_USER1
permit ip any XXXX 0.0.0.3
permit ip any XXXX 0.0.0.15
permit ip any XXXX 0.0.0.31
permit ip any XXXXX0.0.0.7
ip access-list extended YYYY
permit ip XXX 0.0.1.255 any
ip access-list extended BUS
permit ip any XXXXX
permit ip any XXXXX
ip access-list extended CACHE80
deny   tcp any host XXXXXeq www
deny   tcp host XXXXX any eq www
deny   tcp any host 9XXXX eq www
permit tcp X5 any eq www
permit tcp XXXX any eq www
permit tcp XXXX5 any eq www
permit tcp XXXXX.255 any eq www
ip access-list extended CACHE90
permit tcp any XXXX0 0.0.0.255
permit tcp any XXXX8.0 0.0.3.255
permit tcp any 1XXX0 0.0.3.255
permit tcp any 1XXXX6.0 0.0.3.255
ip access-list extended XXXXX
permit ip XXXX0.0.1.255 any
permit ip 1XXXX.3.255 any
permit ip XXXX5 any
permit ip XXXXXXXXDMZ
permit ip any XXX
ip access-list extended VIP
permit ip any XXXXXX
ip access-list extended wireless
permit ip any XXXXXX!
ip prefix-list Y seq 5 permit XXXXX
ip prefix-list Y seq 10 permit XXXX
ip prefix-list YL seq 15 permit XXX
ip prefix-list YL seq 20 permit 1XXX
ip prefix-list2222 seq 5 permit XXXX
ip prefix-list22222 seq 5 permit XXXX
access-list 10 permit XXXX
access-list 100 permit ip host XXXXXX any
access-list 111 permit ip any XXXXX
route-map xxx permit 10
match ip address prefix-list PrefPALTEL
route-map XXX permit 10
match ip address prefix-list XXX
set as-path prepend XX 5XX5 5XX5 5X
route-map xx permit 20
match ip address prefix-list XXXX
route-map XXXX permit 10
route-map XXXXpermit 10
set as-path prepend XXXXXX
route-map XXXX permit 20
route-map CACHE-REDIRECT permit 5
match ip address TO_DMZ
route-map CACHE-REDIRECT permit 10
match ip address 100
set ip next-hop XXXX
route-map CACHE-REDIRECT permit 20
match ip address XXX
set ip next-hop XXXXX!
route-map CACHE-REDIRECT permit 30
match ip address XXXX
route-map CACHE-REDIRECT permit 100
snmp-server community Gateway RO
control-plane
dial-peer cor custom
line con 0
password XXXXXXXX
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password XXXXXXXXX
login
end
15 Replies 15
Hi Ahmed,
would you be more specific on the IOS version? did you enable a logging debug level for undesrtanding what is going on?
something similar can happen when you create a p2p interface or a p2mp int and then your remove the config. The real configuration is not totally removed and this can impact on the new implementations.
Let us know because it is very curious!!!
Alessio
hi ,
i said that the router is hanged , which mean that i cant do anything except restarting the router by plugging the power off ,
the staranger thing is if i removed the cable of interface GI0/1 and return it , the router get natural and every thing is ok !!!!!!!!!!
an way , hers is the ios of my router
Gateway#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 12:11 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)
NS-Gateway uptime is 2 weeks, 2 days, 10 hours, 17 minutes
System returned to ROM by reload at 01:04:17 UTC Wed Dec 1 1999
System image file is "disk2:c7200p-adventerprisek9-mz.124-24.T4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID xxxxxxx
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.0
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
What interface are you using to access the router?
If you are entering the router via the interface that is being modified, an interruption of services may be expected.
Can you also post the script containing the changes you are about to implement?
I don't see any subinterface configuration in the current config.
hi ,
im accessing the router from telnet by the interface gi0/1
i typed interface gi0/2.22
ip add xxxx
the router  hanged and seemed as down
then i removed the cable of Gi0/1 and returned it,====>
evey thing became ok
now i typed
no interface gi0/2.22 ====> the router hanged again
i dont want this problem to occur again and i have no chanes to test because it is a production network !!!
i cant try another onces , because  all users will be down and lose internet ,
regards
Try entering the encapsulation dot1q before entering the IP address.
Also, try connecting to it via Console and provide the logs.
paolo bevilacqua
Remove QoS, update IOS, try again.
hi ,
i want to ask , how QOS affect the  ahnging of the router ????
is it logical that QOS hang the router ???
regards
hi ,
is this page relates to  my issue ?
http://bugs.mysolvr.com/CSCek50380
it seems similar to my problem , but my ios is newer that the ios which has the problem !
regards
hi ,
can i run this config with my ios on GNS3 ??? and test the problem ???\
is it possible ???
regards
GNS3 is useful for control plane related tasks but useless when it comes to data plane testing.
Your case is definitely related to a data plane behavior issue or a configuration/user error.
With that said, you have nothing to lose with GNS3, go right ahead.
i will try , but im wondering if it possible to emulate my config with GNS3  , because im facing errors !!!!!
Hello Ahmed,
as noted by Edison when you configure a new subinterface you should first provide the encapsulation dot1q and then you should be able to configure an IP address.
The correct IOS behaviour, when attempting to configure an IP address on a new subinterface before configuring encapsulation, should be a warning message telling you to configure encapsulation first and the command should be just ignored.
I have seen this every time I missed to enter the encapsulation command.
I would suggest to follow the correct procedure in your next attempt.
I don't think you can emulate tne NPE-G2 on GNS3, and even it  is possible the results are not meaningful
The case that you have found is triggered by the encapsulation command on an interface with policy map applied so it is a different matter.
Hope to help
Giuseppe
hi ,
i tried  creating subintrface on Gi0/2  which does has any policy , u can see it from the above config ,
wondering if i entered  ip before encapsultion on an interface , the router will hang !!!!
i think cisco has a bug like that !
i think this will be a big trouble cause im not able to emulate it !!!
regards
awaisku
Exactly same issue I am facing and unable to resolve. I have the same router 7206VXR with IOS version 12.4(15)T9. I am sure that this is not an encapsulation issue (as mentioned by Giuseppe Larosa) because even when I provide the encapsulation dot1q command before entering the ip address, issue still the same.
Sometimes the router also hangs when I remove the ip address on a sub-interface by giving command "no ip address x.x.x.x x.x.x.x".
The crazy thing is that not every time router hangs. Most of the time, router accepts and removes the ip address perfectly fine.
I am 90% sure that this is a software bug but still finding solution for it.
