The sum of all queue-limit value is greater than the hold-queue value
_|brt.drml|_
Platform : 2911 with ios 15.7(3)
Situation: Tunnel to a central platform over a physical high latency carrier.
Issue: "The sum of all queue-limit value is greater than the hold-queue value"
The exact error is: %QOS-4-QLIMIT_HQUEUE_VALUE_SYNC_ISSUE: The sum of all queue-limit value is greater than the hold-queue value.
I understood of some modern Google work that the total sum of my policy map exceeds the one of the interface.
policy-map PM_QOS_C_V-70-15-0-15
 class CM_QOS_C_VOICE
  priority level 1
  police cir percent 9
 class CM_QOS_C_VIDEO
  priority level 2 percent 5
 class CM_QOS_C_ROUTING
  bandwidth remaining percent 2
 class CM_QOS_C_NETMGT
  set mpls experimental topmost 7
 class CM_QOS_C_CALLSIG
 class CM_QOS_C_PRIORITY
  bandwidth remaining percent 15
  no queue-limit 512 packets
 class CM_QOS_C_INTERACT
  bandwidth remaining percent 20
  fair-queue
  random-detect dscp-based
 class CM_QOS_C_TRANSACT
  fair-queue
 class CM_QOS_C_BULK
  bandwidth remaining percent 5
  fair-queue
 class CM_QOS_C_HIGHNET
  bandwidth remaining percent 13
  random-detect
 class CM_QOS_C_PUBNET
  bandwidth remaining percent 18
  fair-queue
  random-detect
 class CM_QOS_C_DEFAULT
  fair-queue
  random-detect
 class class-default
  random-detect
 I increased on my physical interface the hold-queue value 'out' to 2000. It was based upon a wild guess.
Each queue has 64 packets. If I make the sum off all queues (included the default) I count "832". The physical interface shows me default 1000.
It seems that QoS is still performing fine. No customer complaints and I still see markings and packets leaving the device.
Why does it still tell me this error? Is it a problem of the Tunnel or the Physical interface?
Any ideas are welcome. Thank you.
0 Replies 0
