“This SMP image cannot run on a ASA5505 system.”
drobideau
I put the wrong ASA image on my ASA5505 router  (asa811-smp-k8.bin) and now the ASA55050 will not boot. It just keeps rebooting with the following error message “This SMP image cannot run on a ASA5505 system.”.
How do I put a valid SMP image back on the appliance with the CLI?
I can push Esc while it is booting and get to the command prompt with limited commands listed below.
address   <addr>  local IP address
boot      <args>  boot an image, valid args are:
     - "image file spec" and/or
     - "cfg=<config file spec>"
clear             clear interface statistics
confreg   <value> set hex configuration register
dev               display platform interface devices
erase     <arg>   erase storage media
file      <name>  application image file path/name
gateway   <addr>  gateway IP address
gdb       <cmd>   edit image gdb settings
help              valid command list
history           display command history
interface <name>  ethernet interface port
no        <feat>  clear feature settings
ping      <addr>  send ICMP echo
reboot            halt and reboot system
reload            halt and reboot system
repeat    <arg>   repeat previous command, valid arguments:
     - no arg: repeat last command
     - number: index into command history table
     - string: most recent 1st arg match in command history table
reset             halt and reboot system
server    <addr>  server IP address
set               display all variable settings
show      <cmd>   display cmd-specific information
sync              save variable settings in NVRAM
tftpdnld          TFTP download
timeout   <num>   packet timeout (seconds)
trace             toggle packet tracing
unset   <varname> unset a variable name
krishnakumarr
I need some clarification
May be you have download ASA 5580 version of Image this image
this  image is valid for the ASA 5580-20 and ASA5580-40 ***
U need the software for ASA 5505 Pl find the latest image for ASA 5505
Note: pl verify DRAM and FLASH for load this image
asa805-k8.bin
Release Date: 03/Nov/2009
Cisco Adaptive Security Appliance Software version 8.0(5) software. Please read the Release Note prior to downloading this release.
Size: 13608.00 KB  (13934592 bytes)
Use TFTP /Tftpdnld to load this software
Dan
I have not run into this issue on an ASA and so can not speak from direct experience. But based on the commands that you show as available I believe that your solution will be to use the tftpdnld command to put a correct image on the ASA.
As is suggested by its name tftpdnld uses TFTP to download an image and is typically used to recover when a device has a corrupted image or an incorrect image (as apparently is your case). You will probably need to use the set command to set various variables (especially including the server address of a TFTP server which has the correct image in its TFTP directory, the image name, and the gateway - used if the server is not on the local subnet with the ASA).
Give it a try and let us know how it works.
Rick
Rick
