Showing results forĀ
Search instead forĀ
Did you mean:Ā
Throughput of a Router
pgyogeshkumar
We have limited the throughput of router using below command.
platform hardware throughput limit
Is there any way to check how much it is getting utilized against the limit set with the router
Yogesh
Leo Laohoo
What is the exact model of the router & what is the WAN bandwidth?
Its actually CSR1000v Virtual Router. And we have a 1G interface for External connectivity and bandwidth command is not set in that interface as such for now.
Sunil Bhadauria
I believe " show platform hardware throughput level " should help .
Sunil
