Throughput Router 3925E
alancsantos
Hello all.
How do I find the default throughput supported by the Router 3925E?
I need a router that supports 400Mbps line 3900.
The 3925E supports? If so, you need to upgrade or add a EHWIC? If so, what can I addto support that throughput?
Thanks for the replies.
6 Replies 6
Leo Laohoo
That'll have to be the 3945E.
Check out the White Paper attached.
In Table 1, it states that the 3925E supports more than 400Mbps. See that?
Forgot to mention that the value is expressed in HALF duplex and NO ENCRYPTION.
If you want to run your WAN link with ENCRYPTION and FULL duplex then factor the value by FOUR.
This information is in PDF? Not found.
You won't.  You're not expected to.  Blame the marketing department from every manufacterer.  IT's a very common practice.
Caveat emptor.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Minimum size Ethernet requires 1.488 Mpps per gig, so 400 Mbps duplex would be about 1.2 Mpps.  The 3925E is rated at 1.845 Mpps for minimum size Ethernet, so for just raw forwarding, it should meet your need.
Larger packet size will allow even higher throughput; additional services will reduce throughput.  Cisco recommends the 3925E for up to 250 Mbps, but Cisco's recommendations tend to be very conservative.
