To block URLs on cisco 7507 router
ror.sanjeev
Hi..I hv cisco 7507 router,I need to block some URLs or websites on this..can I do this and how..Please tell me ..
7 Replies 7
wasiimcisco
you can do this by enabling the Nbar on interface and then make class-map test do match protocol http url "*hotmail*"
then make policy-map test
class test
drop
apply the service on interface.
if helpful please rate
I have done same thing as:
class-map match-all test
match protocol http url "youtube"
policy-map test
class test
set ip dscp default
enable ip nbar protocol-discovery on Fa5/1/1
following are access-list applied on fa5/1/1
40 deny ip any any dscp default (105222matches)
50 permit ip any any log (868 matches)
But it blocks all the site not even youtube.I am unable to open any site like yahoo,google,rediff etc.
Please tell me..
You're denying all IP traffic with a DSCP of 0, which is what most traffic is by default.
Try something like this-
match protocol http host *youtube.com*
policy-map test
class test
drop
You can remove the the ACL line 40 & 50.
Hope that helps.
hi..there is no command like drop..
(config-pmap-c)#?
QoS policy-map class configuration commands:
bandwidth Bandwidth
exit Exit from QoS class action configuration mode
fair-queue Flow-based Fair Queueing
netflow-sampler NetFlow action
no Negate or set default values of a command
police Police
priority Low Latency Queueing
queue-limit Queue Max Threshold for Tail Drop
random-detect Weighted Random Early Detect (Precedence based
service-policy Configure Flow Next
set Set QoS values
shape Traffic Shaping
on this link,http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800fc176.shtml
it is written there,u can do with set dscp 1 but i m not able to do.
please tell,
thanks.
Take a look at Method 3 on the link you provided, that would be a way to do it as well.
I have also applied the method (3) from the link http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800fc176.shtml
still I am not able to block youtube.com.Can you please tell me the complete procedure and commands.
I am using Cisco IOS version 12.3(11)T3,cisco 7507 router.
Sanjeev
class-map match-all YOUTUBE
match protocol http host "*youtube.com*"
policy-map DROP_YOUTUBE
class YOUTUBE
drop
interface FastEthernet0/0
description TO INTERNET
service-policy output DROP_YOUTUBE
Hope that helps.
