Tool/s for Automatic Provisioning of Routers?
david-swope
I am looking to find a way of automating the configuration of a couple hundred routers (4400's). I was thinking Prime Infrastructure might work with templates etc. I need to validate that by playing with it but has anyone used any other automation tools? Paid or free is fine, if I am unable to find a means of automating the configurations then I will be manually configuring 200 routers and I don't want that.
I'm also not sure but I was looking at the older Cisco Configuration Engine 3.5 (but no support for 4400's officially)
Thanks in advance
Tinashe Ndhlovu
Take a look at the Cisco Security Manager, i haven't used it yet but it seems to be the sort of tool you might be looking for.
http://www.cisco.com/c/en/us/products/security/security-manager/index.html
cheers
Mmmm, CSM is not something that would fit with what I am looking to achieve.
Joris Koenraadt
I know this is an old post, but did you find any solutions to your question? Especially if it is a open-source program.
