Total counts of static routes with 3925 & 1941.
HCL Support
Hi Team,
My Query : There is requirement to put near 7000 static route towards Null Interface to block black listed public ip address on Internet link router only before firewall. The Router hardware will be Cisco 3925 & Cisco 1941.
The Cisco Hardware & respective software detail also below,
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 995328K/53248K bytes of memory.
System image file is "flash0:c3900-universalk9-mz.SPA.152-4.M6.bin
Cisco CISCO1941/K9 (revision 1.0) with 487424K/36864K bytes of memory.
System image file is "flash0:c1900-universalk9-mz.SPA.150-1.M3.bin"
Also need to share the respective URL for the reference of this raised query.
Ashutosh
Mark Malone
They don't release the specific figures on the docs for static routes as it depends on several factors on ram what features are enabled , resources being used etc. per router , but they can both handle easily that amount of routes , the 3925 with 1gb ram can handle few hundred thousand routes and the 1941 shouldn't have an issue either with that spec
the closest links you will get on specs are the data sheets releases for each model
just google 3925 data sheet and 1941 date sheet
