Total Memory
kokencisco
what's the command to see the total MB of RAM memory and Falsh memory ?
spremkumar
Level 9
Level 9
hi
it can be checked/verified using show version command which will give you both the details..
cisco 1751 (MPC860P) processor (revision 0x300) with 55706K/9830K bytes of memor y.
Processor board ID JAD07090248 (590233665), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
55706K/9830K ----- adds up to 64MB RAM
32768K bytes --- 32MB Flash..
hope this helps u ..
regds
madhavi141
show version command will show you that info...
regards,
Thanks a lot for the answer.
Now i do a SH VERSION on 7200 but i don't understand the total of FLASH
cisco 7206VXR (NPE-G1) processor (revision A) with 491520K/32768K bytes of memory -- 254MB RAM right???
125184K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
where is the FLASH????
Actually this router has 512 MB of RAM. This platform shows memory divided between active memory and I/O packet memory. To see the memory total add 491520K of active memory and 32768K of I/O packet memory to get the total.
You have two different Flash memories on this router. you have 16384K bytes of Flash internal SIMM which is internal flash. And you have 125184K bytes of ATA PCMCIA card which is a flash card in the router. Both of these act as Flash memory for the router.
Rick
Rick
