Total output drops incrementing - ASR1004
Navin_Natarajan
Can someone assist to identify the reasons for the "Total Output Drops" counter incrementing when there are no other output errors?
This interface is SP facing interface which has 6 sub interfaces. But I'm unable to identify from which sub interface the drops are occurring. Please assist.
GigabitEthernet0/0/2 is up, line protocol is up
Full Duplex, 1000Mbps, link type is force-up, media type is SX
output flow-control is on, input flow-control is on
Last input 00:02:11, output 00:00:05, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 134927138
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 36772000 bits/sec, 7423 packets/sec
5 minute output rate 76211000 bits/sec, 13112 packets/sec
73193437309 packets input, 39418789122864 bytes, 0 no buffer
Received 70470 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
121475920140 packets output, 85200669659695 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
12 Replies 12
balaji.bandi
can you post the same output from the subinterface also?
check some troubleshooting tips :
https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/110531-asr-packet-drop.html
BB
Navin_Natarajan
Thank you for the prompt response. below are the requested details.
GigabitEthernet0/0/2.11 is up, line protocol is up
  Hardware is SPA-8X1GE-V2,
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 16/255, rxload 4/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  11.
  Keepalive not supported
GigabitEthernet0/0/2.12 is up, line protocol is up
  MTU 1500 bytes, BW 200000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  12.
GigabitEthernet0/0/2.16 is up, line protocol is up
  Encapsulation 802.1Q Virtual LAN, Vlan ID  16.
GigabitEthernet0/0/2.31 is up, line protocol is up
  MTU 1500 bytes, BW 70000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  31.
GigabitEthernet0/0/2.42 is up, line protocol is up
  Hardware is SPA-8X1GE-V2, a
  Encapsulation 802.1Q Virtual LAN, Vlan ID  42.
this bottle neck issue, the Ingress traffic more than egress traffic and the Queue need to drop packet that can not forward.
Hello
int gig0/0/2
load interval 30
exit
clear counters
Please post interface statistics thereafter
Kind Regards
Paul
Joseph W. Doherty
Generally, as @MHM Cisco World also noted, egress traffic, on that interface arrives faster than it can egress, needing to be queued, and when the queue overflows, packets are dropped
I was going to just further write:
On a gig interface, an egress queue size of 40, is very likely woefully undersized.  (BTW, an egress queue of 40, seems to be a long, long standing default for Cisco, on/for many interfaces, and by my calculation, is, more-or-less, almost an ideal value for 10 Mbps Ethernet or 1.5 Mbps T-1.)
Try increasing your egress queue size to something like 4K and see if drops seem to decrease, w/o any other noted adverse impact to your network applications.
But then, I noticed your interface notes it's using "Queueing strategy: Class-based queueing", so please provide interface and all sub-interface configs, and we'll go from there.
I will not recommend change Queue depth, I prefer he put full QoS plan for ASR.
interface GigabitEthernet0/0/2
 description *****
 no ip address
 no ip proxy-arp
 no negotiation auto
interface GigabitEthernet0/0/2.2
 description *****
 encapsulation dot1Q 2
 vrf forwarding vrf1
 ip address *****
 no ip proxy-arp
 service-policy output *****
interface GigabitEthernet0/0/2.3
 description *****
 bandwidth 200000
 encapsulation dot1Q 3
 vrf forwarding vrf2
 ip address *****
 no ip proxy-arp
 ip flow monitor *****input
 ip flow monitor *****output
interface GigabitEthernet0/0/2.4
 description *****
 encapsulation dot1Q 4
 ip vrf forwarding vrf3
 ip address *****
 no ip proxy-arp
interface GigabitEthernet0/0/2.5
 description *****
 bandwidth 70000
 encapsulation dot1Q 5
 vrf forwarding vrf4
 ip address *****
 no ip proxy-arp
 ip flow monitor ***** input
 ip flow monitor ***** output
 service-policy output *********
interface GigabitEthernet0/0/2.6
 description******
 encapsulation dot1Q 6
 ip address *****
 no ip proxy-arp
Ah, okay, as expected, you're using CBWFQ egress policies.
Since you've redacted so much detail, from your posting, I'm assuming you're very sensitive about what you post.
In that case, if you know how to obtain and analyze CBWFQ interface stats, where you drops are happening, should be revealed in those stats.
If you need help with analysis, you'll need to post those stats, the amount of help possible will be much tied to amount of information you provide.
Further, for additional help/recommendations for possible changes to your CBWFQ policy, we'll need to see the details of current config and what your QoS goals are.
Thank you for the update Joseph. I could see the TAILDROP and WRED packets are incrementing in Global drop stats. Which we can assume the output packets are being dropped due to congestion?
Yesterday stats:-
Global Drop Stats                         Packets                  Octets
BadIpChecksum                                 376                   23688
Disabled                                        1                      64
IpTtlExceeded                            19619242              1390638279
Ipv4NoRoute                                 10834                 5684713
Ipv4Null0                              1027972687             92809940484
QosPolicing                                    30                   42540
TailDrop                                 76633932             89913367358
Wred                                     58327320             35305186208
Today stats:-
Disabled                                        1                      64
IpTtlExceeded                            19749726              1400948276
Ipv4Null0                              1030840628             93078221489
TailDrop                                 76904613             90222554000
Wred                                     58428087             35365163598
The stats you'll want to see are:
sh policy-map <your policy map name> GigabitEthernet0/0/2.2 !and for .3 .. .6
Thank you Joseph. I could see some drop number in class default, is it something i need to focus on?
147/28-RO01#sh policy-map interface gigabitEthernet 0/0/2.2
  Service-policy output: Canada_SHAPE
    Class-map: class-default (match-any)
      95296841783 packets, 71908649154521 bytes
      5 minute offered rate 45021000 bps, drop rate 41000 bps
      Match: any
      Queueing
      queue limit 783 packets
      (queue depth/total drops/no-buffer drops) 0/87336055/0
      (pkts output/bytes output) 95208936719/71841801570422
      shape (average) cir 188000000, bc 752000, be 752000
      target shape rate 188000000
      Service-policy : Canada_QOS
        queue stats for all priority classes:
          Queueing
          queue limit 512 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 117955802/80012935574
        Class-map: Canada_NETWORK (match-any)
          93116350 packets, 10716455538 bytes
          5 minute offered rate 4000 bps, drop rate 0000 bps
          Match:  dscp cs6 (48) cs7 (56)
          Match: ip precedence 6  7
          Queueing
          (pkts output/bytes output) 93116350/10716455538
          bandwidth remaining 2%
        Class-map: Canada_VOIP (match-any)
          117955802 packets, 80012935574 bytes
          5 minute offered rate 62000 bps, drop rate 0000 bps
          Match: access-group name Canada_VZ_SIP_GW
          Match:  dscp ef (46)
          Priority: 50000 kbps, burst bytes 1250000, b/w exceed drops: 0
          QoS Set
            dscp ef
              Packets marked 117955802
        Class-map: Canada_VOIP-SIGNAL (match-any)
          848398536 packets, 490362439469 bytes
          5 minute offered rate 88000 bps, drop rate 0000 bps
          Match: protocol rtcp
          Match: protocol skinny
          Match: protocol mgcp
          Match:  dscp cs3 (24) af31 (26)
          Match: protocol sip
          Queueing
          (pkts output/bytes output) 848398536/490362439469
          QoS Set
            dscp cs3
              Packets marked 848398536
          bandwidth remaining 5%
        Class-map: REAL_TIME_INTERACTIVE (match-any)
          0 packets, 0 bytes
          5 minute offered rate 0000 bps, drop rate 0000 bps
          Match: access-group name -Canada-TP
          Queueing
          (pkts output/bytes output) 0/0
          QoS Set
            dscp cs4
              Packets marked 0
          bandwidth remaining 20%
        Class-map: MULTIMEDIA_CONF (match-any)
          10308744 packets, 4829972798 bytes
          Match:  dscp af41 (34) af42 (36) af43 (38)
          Queueing
          (pkts output/bytes output) 10308744/4829972798
          bandwidth remaining 30%
            Exp-weight-constant: 4 (1/16)
            Mean queue depth: 1 packets
            dscp       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
                    pkts/bytes            pkts/bytes       pkts/bytes          thresh         thresh     prob
            af41    10303562/4827246425      0/0              0/0                341           391  1/10
            af42        5160/2724825         0/0              0/0                292           391  1/10
            af43          22/1548            0/0              0/0                243           391  1/10
          Service-policy : MULTIMEDIA_CONF_PM
            Class-map: LyncVideo-CM (match-any)
              18 packets, 8219 bytes
              Match: access-group name LyncVideo
              QoS Set
                dscp af42
                  Packets marked 18
            Class-map: LyncAudio-CM (match-any)
              0 packets, 0 bytes
              Match: access-group name LyncAudio
              QoS Set
                dscp af41
                  Packets marked 0
            Class-map: LyncData-CM (match-any)
              0 packets, 0 bytes
              Match: access-group name LyncData
              QoS Set
                dscp af43
                  Packets marked 0
              10308726 packets, 4829964579 bytes
              Match: any
        Class-map: CriticalAPP-CM (match-any)
          78415430 packets, 93643947236 bytes
          5 minute offered rate 26000 bps, drop rate 0000 bps
          Match: access-group name BusinessApplication
          Queueing
          (pkts output/bytes output) 78415430/93643947236
          QoS Set
            dscp af21
              Packets marked 78415430
          bandwidth remaining 10%
            af21    78415430/93643947236      0/0              0/0                341           391  1/10
        Class-map: BULK_DATA_CM (match-all)
          0 packets, 0 bytes
          Match: none
          Queueing
            Mean queue depth: 0 packets
          Service-policy : BULK_DATA_PM
            Class-map: Exchange-CM (match-any)
              0 packets, 0 bytes
              Match: access-group name Exchange
              QoS Set
                dscp af12
                  Packets marked 0
            Class-map: ActiveSync_CM (match-any)
              0 packets, 0 bytes
              Match: access-group name ActiveSync
              QoS Set
                dscp af13
                  Packets marked 0
              0 packets, 0 bytes
              Match: any
          94148646877 packets, 71229083390611 bytes
          5 minute offered rate 44831000 bps, drop rate 42000 bps
          Match: any
          Queueing
          queue limit 1248 packets
          (queue depth/total drops/no-buffer drops/flowdrops) 0/87336055/0/29494388
          (pkts output/bytes output) 94060741857/71162235819807
          QoS Set
            dscp default
              Packets marked 94148063760
            Mean queue depth: 3 packets
            class       Transmitted      Random drop      Tail/Flow drop Minimum Maximum Mark
            0       94060741857/71162235819807 15050472/9649245142 42791195/24807698023        312           624  1/10
            1               0/0               0/0              0/0                351           624  1/10
            2               0/0               0/0              0/0                390           624  1/10
            3               0/0               0/0              0/0                429           624  1/10
            4               0/0               0/0              0/0                468           624  1/10
            5               0/0               0/0              0/0                507           624  1/10
            6               0/0               0/0              0/0                546           624  1/10
            7               0/0               0/0              0/0                585           624  1/10
          Fair-queue: per-flow queue limit 312 packets
"I could see some drop number in class default, is it something i need to focus on?"
Well, if you want to try to reduce them, knowing where they are happening is step one.  Then we can try to determine why they are happening.  That said, however, actually the overall drop percentage is only (about) .09%, but that's an overall average.  You might have much higher drop rate percentage during brief periods.  (To determine which, you would need a management tool to graph drop rate, over time, for much shorter time periods.)
The .2 subinterface is the only one showing drops?
I see you're shaping .2; shaping all other interfaces too?  For other subinterfaces, can aggregate of all together exceed physical bandwidth of parent interface?
Is there a reason why you're using WRED and FQ, together, in class-default?  (BTW, I generally strongly recommend those who are not QoS experts not to use WRED at all.  Using WRED and FQ, together, is, in my not so humble opinion, a very bad thing.)
Hmm, WRED stats lists "Tail/Flow drop".  Not sure how to interpret that, as there can be both FQ flow drops and WRED tail drops.  I.e. if both are actually combined, that sort of conceals what's happening.
If you don't have a real need for WRED, while using FQ, I would suggest removing WRED.
Any idea what your BDP (bandwidth delay product) is for this subinterface?  (I've found setting up buffer resources for about half the BDP often works fairly well.)
