TP Link router keep disconnecting
Xamaa
I have got a new TP Link router Archer C24, it transmits both 2.4gHz and 5gHz. The issue I'm facing that it's signals keep disappearing or disconnecting after every hour or 30 mins. And it reappears or reconnects the moment i enter the IP 192.168.0.1 or something like that. Web Hosting
This is a new router and I'm just tired of facing this problem. Any help?
Richard Burts
We do not have nearly enough information to understand what is the issue or to give good advice. For starters:
- can you tell us a bit more about how the router is configured?
- when you say the signal disappears are you saying that the problem is on the wireless side or is it on the wired side?
- where do you enter 192.168.0.1? In what context is this? What is at 192.168.0.1?
- when the problem happens does it impact everyone? Or does it impact some but not all?
Rick
are you running the latest firmware on the C24 ? Did you try changing the chanel and the associated Mhz ?
I found the thread below, it has some suggestions...
Archer C24. Wifi keeps disconnecting frequently. Bandwidth dropdown frequently. - Home Network Community (tp-link.com)
