RIP V2 advertisement
kuriakose1
I'm configuring RIP v2  on Cisco IOS XE 16.x version  ,  my Subnet  is 10. 181.1.0 MASK 255.255.255.0
I need to advertise out  the exact subnet not the full class A
I  don't  want to summarize the address
Is it possible using  RIP v2 ?  if then what commands I  can use
2 Accepted Solutions
Thanks you
My Interface is a Vlan not a physical interface
I assume the solution works the same way
router rip
version 2
no auto-summary
What you advertise based on the network statement is directly related to the interface associated with that command. Understand the
network
command does not advertise that network, rather it is an inclusive list to include these interfaces with an IP in that range for advertising. The network/mask is derived form the interface participating. To enable version 2 of RIP please use the following
router rip
version 2
no auto-summary
network 10.181.1.0
If your interface is a /24 such as 10.181.1.1 255.255.255.0 then it will advertise the /24
Hope that helps
-David
Thanks you
Yes it does.
