trace hop
suthomas1
Level 6
Level 6
Attached is a rough sketch for my question. Site A is connected to SiteB & C over leased line link.
question is pertaining to site B & Site C segments.
Site B uses ip segment 192.168.200.0 /24. So in this case assume coreswitch 1 site B to be having
192.168.200.5 on one of its vlans .
Site C is an extension of site B and the connection between site B and site C is a fiber link and not
any wan connectivity.Site C is connected to Site B over fiber link on a hub vlan with ip segment
192.168.200.10 /28.
Site C uses 192.168.300.0 /24 as its main segment however it has a server vlan 212 which is using
172.16.0.2 /24 as its ip ( for some unknown reasons as its quite legacy ).
Query is:
If i try to trace a server(from Site A) stationed at Site C on its Vlan 212 bearing ip 172.16.0.20,
output doesnt complete after 192.168.200.12 which is the hub interface ip for site c linking to site B.
however a ping from same source completes successfully & connectivity to servers are also fine.
It is only the trace that baffles me.Shouldn't the trace be completing till Vlan 212 or to actual server on site C.
Site C has only a default route throwing all traffic to Site B core switch. Site B has static routes recognising this different subnet 172 from Site C.
Is this normal ? Please help me to understand this behaviour.
Thanks in advance!
Jennifer Halim
Is there any firewall and/or ACL that might be blocking the traceroute?
If you try to trace the other way round, what is the result?
