ā05-13-2010 06:03 PM - edited ā03-04-2019 08:28 AM
We are having two 6500 series switches in same floor. In First switch 6748 line cards is installed with DFC-3 card.
In our Editing workstations are connected to this line card for higher cache as well performance.
In second switch I have installed 6748 line card with DFC-3 card today morning successfully. Unfortunately editing workstations
are not working on new switch even though it is same hardware / switching capability.
When I am troubleshooting I found below difference between two switches kindly refer below.
4th Floor 1st Switch ā Editing workstation is working fine.
DXB-FLR4-SUP#show platform hardware capacity fabric
Switch Fabric Resources
Bus utilization: current: 0%, peak was 10% at 14:26:30 UAE Sun Apr 11 2010
Fabric utilization: Ingress Egress
Module Chanl Speed rate peak rate peak
7 0 8G 0% 3% @16:05 18Oct09 0% 3% @18:41 22Feb09
8 0 20G 0% 5% @21:05 31Jul09 0% 6% @15:26 13Jul09
9 0 20G 0% 14% @18:14 14Apr09 0% 5% @16:24 04Mar09
9 1 20G 0% 25% @21:17 16Dec09 0% 13% @19:38 04Nov09
12 0 20G 0% 14% @19:38 04Nov09 0% 17% @20:46 11Oct09
12 1 20G 0% 5% @15:18 01Oct09 0% 14% @22:30 16Apr09
13 0 20G 0% 5% @16:29 16Mar09 0% 15% @22:44 13Mar09
13 1 20G 0% 6% @12:49 07Mar09 0% 17% @18:21 14Mar09
Switching mode: Module Switching mode
7 truncated
8 flow through
9 compact
12 compact
13 compact
4th Floor 2nd Switch ā Editing workstation is not working
DXB-FLR4-SUP2#sh platform hardware capacity fabric
Bus utilization: current: 0%, peak was 8% at 11:55:34 UAE Wed Nov 18 2009
5 0 20G 0% 10% @16:15 05Dec09 0% 3% @12:07 21Nov09
5 1 20G 0% 3% @13:06 03May10 0% 6% @20:55 09May10
6 0 20G 0% 8% @20:46 09May10 0% 3% @13:06 03May10
6 1 20G 0% 0% 0% 0%
8 0 20G 0% 0% 0% 0%
8 1 20G 0% 0% 0% 0%
9 0 20G 0% 0% 0% 0%
9 1 20G 0% 0% 0% 0%
5 bus
6 dcef
8 dcef
9 dcef
Please let me know can we change switching mode from bus to truncated or flow through on 2nd switch.
Thanks in advance and appreciate the support as ever.
Best Regards,
M Nagarajan
ā05-13-2010 07:14 PM
Hi Nagarajan,
Are you running the same IOS in both devices?
Reza
ā05-15-2010 09:57 PM
Both IOS are exactly same.
ā05-13-2010 09:33 PM
Please do a sho ver to see if the IOS versions are a match on both switches. Please post this information.
thank you
ā05-14-2010 03:56 AM
If you want to allow the modules to run in truncated mode you should use the command:
fabric switching-mode allow truncated
The flow through mode is only supported by CEF256 modules when there is no switch fabric present. If you have CEF720 modules, you may use truncated mode.
Hope this helps.
ā05-15-2010 10:00 PM
Thanks for your response.What will be impact when i will switchover truncated and what
is Cisco's recommendation. If i switch-over to trucated do i require reboot. can any one help on this.
ā05-14-2010 04:17 AM
The would make sense. Looks like the first switch you have a Cat 6513 with sup 720 engine with dual full fabric-enabled cards in slots 9 - 13 for dual fabric connected cards for eample WS-X68xx and WS-67xx hence why you are using compact mode used for those cards. The compact mode is used when no nonfaric-enabled modules are installed.
what is the sup on the second switch?
post "show module" on both switch..
ā05-15-2010 09:58 PM
Both are sup-720.
ā05-16-2010 07:14 AM
Could you please find module details below.
------------------ show module ------------------ In 6513 where everything is working fine
Mod Ports Card Type Model Serial No.
1 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125S35R
2 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125RXAV
3 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125S1PD
4 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125S359
5 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125RXAS
6 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1125RXBE
7 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAL1125RT9D
8 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1125RT9V
9 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1124RBTF
10 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1201BT28
11 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1201C2VM
12 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1203D8FU
13 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1204E9L7
------------------ show module ------------------ 6509E where editing workstation is not working
1 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1204DWA4
2 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1204DUZF
3 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1204DW93
4 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1204DW91
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL1201BS3J
6 5 Supervisor Engine 720 10GE (Hot) VS-S720-10G SAL1201BS34
7 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-45AF SAL1203DFYR
8 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1325SDU6
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1324S80D
