Traceroute / ICMP Question
Alexander Deems
I am trying to get a better understanding of how to read this traceroute because there is nothing blocking icmp on the test network I have setup. I am also not sure why there are multiple entries for hop 4. Shouldn't there only be a single hop?
R1#traceroute 6.6.6.6
Tracing the route to 6.6.6.6
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4 10.5.6.6 240 msec
    10.6.7.6  232 msec
    10.5.6.6  212 msec
Thank you,
Alex
cadet alain
Cisco IOS uses UDP for traceroute not ICMP and it sends 3 probes with same TTL to different udp destination ports so that's why you see the 2 different IP adresses because you have 2 paths to destination.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml#traceroute
Alain
cadet alain
Alain
