traceroute interview question
Hello guys,
                 When we trace route one ip address why it show 3 packets with 3 different types of ms value on every hop. Please explain .It is interview question .
Giuseppe Larosa
Hello Abhishek,
Because traceroute discovery actually makes three attempts for each TTL value to find out intermediate router hops.
This allows to see if there are some alternative next-hops in the path.
Even if a single path / single next-hop exists it reports the results of each attempt so you see three measures of delay expressed in ms for each hop.
The delay measure is possible for the presence of timestamps in the probe packets.
After having done the three attempts the router will increment the TTL by 1 before sending other three probes and so on until the final destination is reached or the maximum number of hops is reached (default to 30).
Actually also the UDP destination port is incremented.
See the link below:
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/12778-ping-traceroute.html#traceroute
Hope to help
Giuseppe
luis_cordova
Joseph W. Doherty
In addition to what other posters have noted, BTW, using 3 probe packets is a default setting. I.e. you can do more or less, if you configure the number of probes to be used.
Joseph W. Doherty
I'm unaware of any show commands that would answer your questions.
Could you expand upon why you have these questions?
