traceroute reports remote PE MPLS label
tomc.pnnl
Consider the diagrammed MPLS configuration
CE1 .a -- .b PE1 -- P1 -- P2 -- PE2 .c -- .d CE2 .e
and "no mpls ip propagate-ttl" configured at PE1, P1, P2, and PE2.
A trace route from CE1 to CE2 reports a MPLS label when egressing PE2:
Tracing the route to .e
VRF info: (vrf in name/id, vrf out name/id)
1 .b 21 msec 16 msec 11 msec
2 .c [MPLS: Label 19 Exp 0] 11 msec 19 msec 10 msec
3 .d 8 msec * 25 msec
In other examples, I thought PE2 would not show in a traceroute. Why in my case is a label being leaked? What can I do to hide it?
5 Replies 5
balaji.bandi
You should not see when you configured "no mpls ip propagate-ttl" configured at PE1, P1, P2, and PE2.
what device is this, try clear LDP session after adding the above command  and re-visit device config and test
here is the reference :
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/26585-mpls-traceroute.html
BB
Thanks. I did clear the ldp sessions and reviewed
I do not see anything relevant in the device configs. The MPLS pcaps match my expectations. Currently, the CE1 and CE2 can communicate. Its just that when either performs a traceroute one sees the egress interface on the egress PE.
Do you have any suggestions what I should focus my attention?
could be a bug. What device is the one sending the label ?
--> 2 .c [MPLS: Label 19 Exp 0] 11 msec 19 msec 10 msec
Post the output of 'sh ver' from that device.
is this LAB (kinda virtual ) or real gear.
if real gear kindly posts the device versions and what model of all device.
other input required what is the outcome when you do traceroute  CE2 to CE1?
BB
I think this is the normal
trace route will show
ingress PE
egress PE
CE
make P hidden from trace route.
why egress PE?
because of label is 3 from last P, PE will do IP lockup and reduce the TTL which make it 0 and send TTL exceed to CE.
