Tracerouter issue
CSCO10758684
Hai all,
from my router tracerotue to any of the sites is not happening .. i am able to browse and also ping ...
is there any command that cab block Traceroute????
when iam connecting laptop directoy to router eth port ... i am able to trace from pc ...but from router its not going to any were
can some one help me ....
XXXXX>en
Password:
XXXX#traceroute 209.x.x.158
Tracing the route to 209.x.x.158
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * *
s.arunkumar
Level 3
Level 3
hi
traceroute can be blocked using accesslist..
eg:access-list 100 deny icmp any any traceroute
may be access list blocking traceroute originated from the router..
for ur info::traceroute uses port udp-33434
hai kumar ,
thanks for your reply i will check the same with the customer and let you know ...
Lijesh
