Bookmark
Subscribe
2719
Tracert shows intermittent failing routers
jnriopel1
I am having strange problems on a Windows PC trying to connect to some sites, and a tracert seems to show that each time the problems start happening, some routing issues deep within my path are failing.  I don't know if it's the ISP's fault or who'se.  Weird thing is other PCs connected to the same ADSL router show a different route.  To wit,
Tracing route to egph34.ddns.net [70.49.244.204] over a maximum of 30 hops:
  1     5 ms     2 ms     6 ms  dsldevice.lan [192.168.1.254]
  2    84 ms    22 ms    22 ms  dsl-servicio-l200.uninet.net.mx [200.38.193.226]
3    94 ms    62 ms    63 ms  bb-la-grand-4-tge0-13-0-0.uninet.net.mx [201.125.8.114]
4   102 ms   103 ms   102 ms  12.123.132.222
5   102 ms   103 ms    99 ms  12.123.132.222
6   109 ms   136 ms   115 ms  cr2.sffca.ip.att.net [12.122.31.134]
7   123 ms   108 ms   119 ms  cr1.st6wa.ip.att.net [12.122.31.193]
8   106 ms   105 ms   103 ms  gar8.st6wa.ip.att.net [12.122.111.13]
9   114 ms   103 ms   106 ms  12.94.202.18
10   132 ms   131 ms   131 ms  core2-seattle_ge8-1-0.net.bell.ca [64.230.186.45]
11   135 ms   130 ms   130 ms  tcore4-vancouverbg_hundredgige0-5-0-0.net.bell.ca [64.230.79.99]
12   133 ms   130 ms   131 ms  tcore4-toronto21_hundredgige1-3-0-0.net.bell.ca[64.230.79.62]
13   132 ms   134 ms   131 ms  tcore4-ottawatc_pos0-0-14-0.net.bell.ca [64.230.49.136]
14   132 ms   125 ms   126 ms  dis9-ottawa10_xe7-0-0.net.bell.ca [64.230.49.207
15   129 ms   129 ms   130 ms  bas4-ottawa10_10G1-0-0_100.net.bell.ca [64.230.98.121]
From Gateway (Weird)
:\Users\Jacques>tracert egph34.ddns.net
Determination de l'itinéraire vers egph34.ddns.net [198.18.1.176] avec un maximum de 30 sauts :
1     3 ms     3 ms     5 ms  dsldevice.lan [192.168.1.254]
2    23 ms    22 ms    22 ms  dsl-servicio-l200.uninet.net.mx [200.38.193.226]
3    62 ms    62 ms    60 ms  bb-la-grand-4-tge0-12-0-8.uninet.net.mx [200.38.93.113]
4     *        *        *     Délai d'attente de la demande dépassé.
5     *        *        *     Délai d'attente de la demande dépassé.
6     *        *        *     Délai d'attente de la demande dépassé.
It always seems to fail after hop 3 (bb-la-grand-4-tge0-12-0-8.uninet.net.mx
How do I begin to find my problem? TIA
admin11111
Level 4
Level 4
Since the proplem is exposed at a PC, a pathping may help you determine where the loss is located better than a traceroute.
PathPing
