Track Command Completely Missing
smith7paul
Visitor
Hi Guys,
I have to create a fail-over on this older branch router. The router is still new enough to have the 'track' command but it does not have it. Anybody know why it would be missing? See below;
ccc_BackUp#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ccc_BackUp(config)#ip sla 1
ccc_BackUp(config-ip-sla)#exit
ccc_BackUp(config)#exit
ccc_BackUp#conf t
ccc_BackUp(config)#trac
ccc_BackUp(config)#trac?
% Unrecognized command
ccc_BackUp#sh vers
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 01-May-07 08:56 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
KDR_BackUp_OCC uptime is 3 days, 22 hours, 27 minutes
System returned to ROM by reload
System image file is "flash:c850-advsecurityk9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 857W (MPC8272) processor (revision 0x300) with 59392K/6144K bytes of memory.
Processor board ID FHK130523G9
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 802.11 Radio
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
Georg Pauwen
I am not sure if that (850) router supports tracking at all. Try dialer watch or backup interface, as described in the document below (section 13-1 Configuring Dial Backup and Remote
Management):
https://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
