track # rtr 1 reachability command
jbahm
I am running a Cisco 2621 router with Enterprise Base 12.3(10c).
I am tring to configure the router for the Multiple Tracking Options of PBR.
all goes well until I try to enter the
"track 123 rtr 1 reachability" command,
the router does not have an rtr selection after I enter "track 123 ?".
I am following a step by step guide in a document "PBR support for Multiple Tracking Options"
Am I missing something?
I am in the process of adding a second ISP to my site and want to be able to detect if ether ISP is down and route traffic to the alternate path.
smahbub
Level 6
Level 6
Please make sure that you are giving this command from the global configuration mode. Also ensure that there is no space in the object number because i see that you have given space in the query that you have sent,please check on this aspects i guess it should work.
b-watkins
You need to be running a newer version of code. PBR support for multiple tracking options requires at least 12.3(4)T.
