Track status through SNMP
nesterove
Hi!
Router checking availability host through track:
track 123 rtr 1 reachability
delay down 100
where
rtr 1
type echo protocol ipIcmpEcho XXX.XXX.XXX.XXX source-ipaddr YYY.YYY.YYY.YYY
rtr schedule 1 life forever start-time now
I can see following information from console:
router#sh track 123
Track 123
Response Time Reporter 1 reachability
Reachability is Up
33 changes, last change 20:14:15
Delay down 100 secs
Latest operation return code: OK
Latest RTT (millisecs) 144
Tracked by:
ROUTE-MAP 0
How can I see track status through SNMP?
regards
Craig Balfour
As far as I know there is no MIB for accessing object tracking via SNMP.
The best you can do access information about your Service Assurance Agent (SAA) / rtr job using the CISCO-RTTMON-MIB mib.
Use the following URL to see more about the CISCO-RTTMON-MIB in SNMP Object Navigator:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.42
Craig Balfour
Thank you Graig!
It's usefull info! I have found required parametr:
.iso.org.dod.internet.private.enterprises.cisco.ciscoMgmt.ciscoRttMonMIB.ciscoRttMonObjects.rttMonCtrl.rttMonCtrlOperTable.rttMonCtrlOperEntry.rttMonCtrlOperTimeoutOccurred
.1.3.6.1.4.1.9.9.42.1.2.9.1.6
if false - then all ok
if true - host unreachable
