Tracking state flapping but not visible in IP SLA
chrishogewoning
Hello all,
Im only a youngtimer in the Cisco world and got into a problem i dont get.
I have configured two Cisco 877 routers with IOS 12.4(24)T8 with a ADSL connection.
On the backup router i see a lot of state changes in the log.
Apr 13 16:23:27.096: %TRACKING-5-STATE: 20 ip sla 20 reachability Up->Down
Apr 13 16:23:30.081: %TRACKING-5-STATE: 20 ip sla 20 reachability Down->Up
Apr 13 21:26:51.707: %TRACKING-5-STATE: 20 ip sla 20 reachability Up->Down
Apr 13 21:26:54.707: %TRACKING-5-STATE: 20 ip sla 20 reachability Down->Up
Apr 13 23:45:08.703: %TRACKING-5-STATE: 20 ip sla 20 reachability Up->Down
Apr 13 23:45:11.704: %TRACKING-5-STATE: 20 ip sla 20 reachability Down->Up
Apr 14 04:34:38.032: %TRACKING-5-STATE: 20 ip sla 20 reachability Up->Down
Apr 14 04:34:41.033: %TRACKING-5-STATE: 20 ip sla 20 reachability Down->Up
Apr 14 10:32:23.237: %TRACKING-5-STATE: 20 ip sla 20 reachability Up->Down
Apr 14 10:32:26.238: %TRACKING-5-STATE: 20 ip sla 20 reachability Down->Up
Im not sure why this happens as i dont see the fails back when looking at the IP SLA.
BACKUP#show ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 20
Type of operation: icmp-echo
Latest RTT: 36 milliseconds
Latest operation start time: 11:12:43.779 UTC Fri Apr 14 2017
Latest operation return code: OK
Number of successes: 401
Number of failures: 1
Operation time to live: Forever
The IP SLA is configured as followed.
ip sla 20
icmp-echo 8.8.8.8 source-interface ATM0.35
frequency 5
The IP SLA 20 is combined with Track 20.
BACKUP#show track 20
Track 20
IP SLA 20 reachability
Reachability is Up
586 changes, last change 00:03:28
Delay down 2 secs
Latest RTT (millisecs) 36
Tracked by:
HSRP Vlan100 100
Does any one have any idea why the track 20 has so many changes while the IP SLA only has one failed attempt?
Im not sure if more information is needed, if so let me know and i will post it.
Chris
Hello Chris,
how is the backup router connected to the other one ? Can you post the full config of both routers ?
Hi Georg,
The routers are connected with a unmanaged gigabit switch.
Pretty default config for testing reasons.
Backup router
no service pad
hostname Backup_ADSL
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 52000
enable secret xxxxxxx
aaa new-model
aaa authentication login default enable
aaa authentication enable default enable
aaa session-id common
dot11 syslog
ip source-route
ip dhcp pool WiFi
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
dns-server 8.8.8.8 4.2.2.2
lease 0 2
ip cef
no ip domain lookup
ip domain name BACKUP.local
no ipv6 cef
username administrator privilege 15 secret xxxxxxxx
archive
log config
hidekeys
ip ssh logging events
ip ssh version 2
track 20 ip sla 20 reachability
delay down 2
interface Loopback1
description SSH-ACCES
ip address 10.11.12.13 255.255.255.0
ip nat inside
ip virtual-reassembly
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.35 point-to-point
description ADSL
ip address dhcp
ip nat outside
ip tcp adjust-mss 1452
atm route-bridged ip
pvc 0/35
encapsulation aal5snap
interface FastEthernet0
description WiFi 192.168.20.253
switchport access vlan 20
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description UPLINK for SWITCH HSRP
switchport access vlan 100
interface Vlan1
no ip address
interface Vlan20
description WiFi
ip address 192.168.20.254 255.255.255.0
ip nat inside
interface Vlan100
description Voice Backup
ip address 192.168.101.252 255.255.255.0
ip nat inside
standby 100 ip 192.168.101.254
standby 100 timers 1 3
standby 100 preempt
standby 100 name VOICE
standby 100 track 20 decrement 10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 217.171.224.193
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 100 interface ATM0.35 overload
ip nat inside source static tcp 10.11.12.13 22 interface ATM0.35 22
ip sla 20
frequency 5
ip sla schedule 20 life forever start-time now
access-list 99 permit 5.34.232.0 0.0.7.255
access-list 100 permit ip any any
control-plane
banner login ^C
__ _.-"` `'-.
/||\'._ __{}_(
|||| |'--.__\
| L.( ^_\^ WARNING : Unauthorized ACCESS is prohibited
\ .-' | _ | and will be logged !
| | )\___/
| \-'`:._]
\__/; \^C
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 99 in vrf-also
logging synchronous
transport input ssh
scheduler max-task-time 5000
end
And the main router
no service pad
hostname VOICE_Main
boot-start-marker
boot-end-marker
logging buffered 520000
enable secret xxxxxxxx
aaa new-model
aaa authentication login default local
dot11 syslog
ip source-route
ip dhcp pool VOICE
network 192.168.101.0 255.255.255.0
default-router 192.168.101.254
lease 1 1 1
ip cef
ip host RT2 192.168.101.252
ip host RT1 192.168.101.253
no ipv6 cef
username administrator privilege 15 secret xxxxxxxxxxx
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
track 100 ip sla 100 reachability
delay down 2 up 30
interface Loopback1
description for remote acces
ip address 10.11.12.13 255.255.255.255
ip nat inside
interface ATM0
no ip address
no ip proxy-arp
interface ATM0.34 point-to-point
ip address dhcp
no ip proxy-arp
ip nat outside
pvc 0/34
description VOICE
spanning-tree portfast
shutdown
shutdown
shutdown
interface Vlan1
shut
interface Vlan100
description VOICE
ip address 192.168.101.253 255.255.255.0
ip nat inside
standby 100 priority 120
standby 100 preempt
standby 100 track 100 decrement 30
ip route 8.8.8.8 255.255.255.255 81.28.82.1 track 100
ip route 0.0.0.0 0.0.0.0 81.28.82.1
no ip http server
ip nat inside source list 100 interface ATM0.34 overload
ip nat inside source static tcp 10.11.12.13 22 81.28.82.45 22 extendable
ip sla 100
icmp-echo 8.8.4.4
request-data-size 200
timeout 3000
threshold 1000
frequency 5
ip sla schedule 100 life forever start-time now
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 5 0
transport input ssh
end
Hello
It is possible if the sla misses a ping then the tracking could poll again before another sla ping and the tracking will kick in and down your hrsp state.
Verify that the destination sla address is indeed reachable, and also try increasing the delay to the tracking for the down state.
track 20
delay 30 down
res
Paul
Kind Regards
Paul
