Tracking with ip sla and shut an interface.
hi all
this is my topologie what i want to do is :
configure tracking in R1 to track ip address in FE 0/0 in R2 ;
then if this ip addresse is unreachable with sla iwant to put interface FE0/1 in R1 to shutdown status
i'm thinking to do events applet ??!!
can some one help me
thanks .
Hi ,
You do not need sla for this in real world, for direcly connected routers via ethernet. When R2 will shut down it's interface R1's interface will go down. But because I belive that you are using GNS3/Dynamips you will need sla
! real life
track 1 interface fa0/0 line-protocol
! gns3
ip sla monitor 1
type echo protocol ipIcmpEcho
timeout 50
frequency 5
ip sla monitor schedule 1 life forever start-time now
event manager applet FA0/0-DOWN
event track 1 state down
action 1 cli command enable
action 2 cli command "conf t"
action 3 cli command "int fa0/1"
action 4 cli command shut
action 5 cli command exit
Dan
5 Replies 5
Hi ,
! real life
! gns3
ip sla monitor 1
timeout 50
frequency 5
Dan
thanks dan;
your idea has guide me to the right config ;i add just an event manager to set interface to no shut if the link if the the link is resrablished.
this is my config and it's work :
ip sla 10
icmp-echo 10.0.0.2
timeout 500
frequency 3
ip sla schedule 10 life forever start-time now
track 10 rtr 10 reachability
delay down 5 up 10
event manager applet RAMDANE
event track 10 state down
action 1 cli command "enable"
action 3 cli command "inte fa 0/1"
action 4 cli command "shut"
action 5 cli command "end"
event manager applet RAMDANEU
event track 10 state up
action 4 cli command "no shut"
if some have a better post it .
ramdane
regards
Hi Ramdane,
The config looks ok.
Dan
thanks many DAN
Hey!
Can you tell me  what "event manager applet..." command does in your config? I want to do some similarly configuration for interfaces where i have MC connected...
Thank's!
Roxana.
