Traffic limitation
burhanburhan
I have 5 mbps line speed and want to limit file transfer traffic 1 mbps, (shouldn't pass this speed) and 4 mbps to ERP. (Between site A and B)
How can i do that with qos?
P.S : We want to limit the file transfer traffic to 1 mbps even link is empty(no congestion) And we dont use routing protocol.
13 Replies 13
you need to police the traffic on any one of your router interfaces
the document below gives details
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus1000/sw/4_0/qos/configuration/guide/nexus1000v_qos/qos_4policing.pdf
Hello Joseph,
My last configuration as below, but still full bandwidtch can be used for file sharing, i want to limit this to 1 Mbps.
i can see smb packets matched by "show policy-map interface" command.
Can you please check this ?
access-list 102 permit tcp any any eq 445
class-map match-all SMB
match access-group 102
policy-map SampleShape
class SMB
shape average 1000000
interface Vlan2
bandwidth 5120
service-policy output SampleShape
Router#sh policy-map interface
Vlan2
Service-policy output: SampleShape
Class-map: SMB (match-all)
271103 packets, 301759861 bytes
5 minute offered rate 3985000 bps, drop rate 0000 bps
Match: access-group 102
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
shape (average) cir 1000000, bc 4000, be 4000
target shape rate 1000000
Class-map: class-default (match-any)
78706 packets, 5125483 bytes
5 minute offered rate 1000 bps, drop rate 0000 bps
Match: any
(pkts output/bytes output) 3731/403578
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Richard already noted, you might police your file transfer traffic.  Another option, on some platforms, would be to shape the traffic instead.
You noted you want to do this all the time, but unless there's a real need to restrict your file transfer traffic all the time, you might also want to consider using QoS to prioritze your ERP over your file transfer traffic.  When there's congestion, you can use QoS to insure ERP gets 4 Mbps vs. file transfer's 1 Mbps, but it would allow file transfer traffic to use bandwidth otherwise unused.  (Assuming you're paying for 5 Mbps, why not take full advanage of it anytime you can?)
Our customer wants to limit this traffic all the time. Can you send me a sample configuration plz. I really don't have knowledge about qos.
Platform and IOS version?
Cisco 888,
c880data-universalk9-mz.152-4.M4.bin
Disclaimer
Posting
class-map match-any fileXferSample
match protocol ftp
policy-map SamplePolice
class fileXferSample
police average 1000000
thank you Joseph, should i use both police average and shape average commands or just one of them ? And how should i apply to interface ? Outbound or inbound?
Disclaimer
Posting
Either the policer or shaper.
Applied to interface (something) like:
interface x
service-policy input|output Policy-name
Policer can be used for input or output, shaper only output.
Hello, sorry for the delay, our customer could test configuration recently.
our configuration as below, customer tries file sharing between two sides (i think it uses smb protocol) Can i match this file sharing traffic by this qos configuration?
match protocol ftp
police 1000000
interface Vlan2
bandwidth 5120
ip address 172.27.219.174 255.255.255.252
service-policy input SamplePolice
Disclaimer
Posting
I would expect not, as SMB doesn't use FTP.
Can i match SMB traffic by configuration as follows ? Have you ever tried this way ?
Disclaimer
Posting
Yup, that might work for fine later Windows systems.  If you've earlier Windows versions, you might also want to match against NetBIOS/NetBEUI protocols.
Also, depending on what version of IOS you're using, NBAR might have a protocol for it.
