Traffic load balancing over 2 DSL cards
ffranco123
Hi.
I need a little bit of help.I have configured on my router 2 dsl cards,one of them with Dynamic IP,and the other with DHCP.I want to configure 20%(Dynamic Ip)of traffic it goes for the first circuit ,and 80% for the secundary line(DHCP)using load balancing.Can somebody help me?
Thanks in advance.
Giuseppe Larosa
hello Francisco,
you cannot achieve this
you can perform load balancing if you add two default static routes with same AD
ip route 0.0.0.0 0.0.0.0 next-hop-ip-link1
ip route 0.0.0.0 0.0.0.0 next-hop-ip-link2
or you can have a primary and a backup path
ip route 0.0.0.0 0.0.0.0 next-hop-ip-link2 200
in this second case until link1 is up link2 is not used for outbound traffic
Hope to help
Giuseppe
