traffic not return in IPSEC tunnel
davy.timmermans
Level 4
Level 4
What are possible reasons that traffic doesn't return in an IPSEC tunnel?
I see with sh crypto ipsec sa that packets become encrypted at the sending site and decrypted at the remote site but they doesn't return. :-(
1)routing problem at the other side
2)blocking ACL outbound at the other side
3) other ?
It's for an environment terminitating normally tunnel interfaces in IPSEC mode but now also with a dynamic crypto map tunnel.
Can it be that traffic is 'pulled'at the other side in another tunnel and then dropped?
Peter Paluch
Hello Davy,
Can you at least confirm that, say, a ping packet sent from one end arrives and is understood on the other end? Try the debug ip packet and debug ip icmp for this purpose (these commands can be quite verbose if the router is under load). Try to find out if an ICMP echo packet is received on the other end, whether a response is created and how is it routed.
Can you also please post here the relevant parts of the configuration of the both routers regarding the entire IPsec configuration including the routing entries?
Did it work at all at some time in the past? If it did, what has changed in your network since it was working?
Best regards,
Peter
Hi Davy,
What first comes to my mind, without deeper delving into the matter:
Did you configure the "reverse-route" command in the dynamic crypto map?
This command dynamically puts a static route into the routing table of the VPN Server router pointing to the other end of the tunnel.
Cheers:
Istvan
Hi all,
It worked in a lab but not in the real environment.
I didn't use the reverse-route command because it worked for one site at time in the lab ( and it was decribed in the documentation that it could work only for one crypto map.
As applied in the lab:
crypto dynamic-map DM_profile 10
set transform-set ts1
match address 101
reverse-route
crypto dynamic-map DM_profile 20
match address 102
reverse-route
It worked for each spoke but not for the situation that both spokes where down.
But I've seen yesterday that it's not needed to define interesting traffic at the dynamic side. So the solution could be easier
reverse-route
This could work because it's applied under 1 cryptomap (as discussed in the docs). Although Im'not sure if it would work for two sites falling on backup. I'll test this Monday
As we added one site as test I finally added the reverse-route command but although it didn't work.
@Peter
I do a ping from the loopback of the spoke towards a loopback of the hub
interface: FastEthernet0/1
Crypto map tag: static, local addr 3.3.1.1
protected vrf: (none)
local ident (addr/mask/prot/port): (30.0.0.0/255.0.0.0/0/0)
remote ident (addr/mask/prot/port): (172.16.0.0/255.255.0.0/
current_peer 1.1.1.1 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 10, #pkts encrypt: 10, #pkts digest: 10 <---------
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0 <---------
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
interface: FastEthernet0/0
Crypto map tag: CM, local addr 1.1.1.1
local ident (addr/mask/prot/port): (172.16.0.0/255.255.0.0/0/0)
remote ident (addr/mask/prot/port): (30.0.0.0/255.0.0.0/0/0)
current_peer 3.3.1.1 port 500
PERMIT, flags={}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0 <--------
#pkts decaps: 10, #pkts decrypt: 10, #pkts verify: 10 <--------
Why I think about the other tunnel was that I
interface: Serial1/0.201
PERMIT, flags={}
#pkts encaps: 13, #pkts encrypt: 13,
#pkts digest: 13
#pkts decaps: 13, #pkts decrypt: 13, #pkts verify: 13
#send errors 2, #recv errors 0
local crypto endpt.: 10.102.0.2, remote crypto endpt.: 10.102.0.1
path mtu 1500, ip mtu 1500, ip mtu idb Tunnelxxx <----
I thought I saw here not the outgoing interface but some tunnel. When I checked this tunnel it hadn't an overlapping route.
current outbound spi: 0x8590D11F(2240860447)
Configuration
HUB
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key THEKEY address 2.2.0.1
crypto isakmp key THEKEY address 3.3.0.1
crypto isakmp key THEKEY address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ts1 esp-aes esp-sha-hmac
crypto ipsec profile IP_S_Profile
crypto dynamic-map dm_profile 10
match address remote
crypto map dm 10 ipsec-isakmp dynamic dm_profile
interface Tunnel1
tunnel source FastEthernet0/0
tunnel destination 2.2.0.1
tunnel mode ipsec ipv4
tunnel protection ipsec profile IP_S_Profile
interface Tunnel2
ip address 192.168.2.1 255.255.255.0
tunnel destination 3.3.0.1
interface fas0/0
crypto map dm
int lo0
ip add 172.16.0.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 fas0/0
access-list remote
spoke
encr aes
group 2
crypto isakmp key THEKEY address 1.1.1.1
!Corresponds with dynamic crypto on hub
crypto map static 1 ipsec-isakmp
set peer 1.1.1.1
match address 100
interface Loopback0
ip address 20.20.20.20 255.255.255.255
access list 100 permit lo0 ->loopbHub
over the tunnel interface, RIP is used and a floating static towards backup interface.
In the real environmont, they have lot's of different IPSEC tunnels operating (via tunnel interface but also pure static) but no dynamic tunnels yet.
Although it didn't worked in the real environment, it has to ;-)
