Traffic Shaping on 3750E Help
Amir Yanny
Hey Guys,
I have a location that has a 3750E facing the provider. The Provider is policing the traffic on their end to 900Meg. Recently the business introduced new service and we are pumping way more traffic over the link facing the provider.
I am thinking of traffic shaping the traffic on the 3750E however the platform has limitations when it comes to this huge traffic..
What is the best solution in this case to limit the egress traffic on this platform? it is a (24-port 3750E) switch running IOS version (15.0(2)SE6).
Traffic path is:
LAN--->3750E(1Gig interface)--->Provider Switch (capping to 900Meg).
Thoughts?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Try:
srr-queue bandwidth limit weight1
On egress gig port.  Start with 90 for weight1, but as this command isn't exact, you may need to reduce to insure you don't exceed 900 Mbps.
Thanks Joseph.
What is the impact of this command on any traffic that exceeds the 900Meg while existing the interface on the switch?
Disclaimer
Posting
It's queued.
