translate tcp to x25
rebert
hio, I`ve a problem with my tcp to x25 conversation. my client works with tcp. it communites with a x25 server. I put a router to the networks witch makes the protocol translation.the tcp handshake works well, but after the handshake the router sends a 12 byte data pattern to the client. I think the datapattern are control data. The client has problem with this pattern and sends a reset to the client. Is it posible to supress this data packet with 12 byte lenght.
the configuration:
x29 inviteclear-time none
x29 profile POST 1:0 2:0 3:0 4:2 5:0 6:0 7:0 8:0 9:0 10:0
x25 routing
interface Serial1/0
no ip address
encapsulation x25
x25 address 46437055
x25 htc 5
x25 ips 256
x25 ops 256
x25 idle 5
serial restart-delay 0
lapb T1 1600
lapb N2 9
no clns route-cache
translate tcp 172.19.16.13 port 8054 x25 464113482 profile POST quiet swap
x25 route 464113482 interface Serial1/0
thanks for help
p.krane
Level 3
Level 3
check out the following link for X.25 to TCP translation, see if it helps :
http://www.cisco.com/en/US/tech/tk713/tk730/technologies_configuration_example09186a0080094a46.shtml
cvasquezm
I have the same problem. The X25 device don?t accept a call with "pad" pattern, and is impossible to modify the CUD.
Do you have an idea to resolve this?
Best regards.
Christian
