Transparent Web proxy - Wccp with Squid
jdczerwinski
I have configured a Squid3 proxy server on Debian using WCCP to a Cisco 2821 router (via GRE tunnel). Regular HTTP traffic works just fine. Anytime I try to connect to HTTPS, it times out.
I've compiled Squid with --enable-ssl.
The squid configuration is as follows:
# Squid3 Configuration
# Cisco Router at 10.50.40.1
# GRE tunnel to Ciso Router at 10.50.1.1 # # Local Squid3 server
# name: wwifi-atl-squid1
# IP: 10.50.40.100
# WCCPv2 (Transparent mode)
visible_hostname wwifi-atl-squid1
# cache_effective_user squid squid
http_port 10.50.40.100:3128 transparent
hierarchy_stoplist cgi-bin ?
acl QUERY urlpath_regex cgi-bin \?
cache deny QUERY
acl apache rep_header Server ^Apache
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern . 0 20% 4320
# Access Control List Definitions
acl localnet src 10.50.10.0/24 10.50.20.0/24 10.50.30.0/24 10.50.40.0/24 10.50.100.0/24 10.50.201.0/24
acl manager proto cache_object
acl localhost src 127.0.0.1/255.255.255.255 acl to_localhost dst 127.0.0.0/8
acl SSL_ports port 443 563 # https, snews
acl SSL_ports port 873 # rsync
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 563 # https, snews
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl Safe_ports port 901 # SWAT
acl purge method PURGE
acl CONNECT method CONNECT
# http allows/denies
always_direct allow all
http_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow localhost
http_access allow localnet
http_reply_access allow all
icp_access allow all
debug_options ALL,1
# Following options are for transparent mode wccp2_router 10.50.40.1 wccp2_rebuild_wait on wccp2_forwarding_method 1 wccp2_return_method 1 wccp2_assignment_method 1 wccp2_service standard 0 wccp2_address 10.50.40.100
simontibbitts
Hello.
What is your configuration and IOS version on the Cisco 2821 router? First thing that jumps out at me is you might be running only WCCP version 1 which supports only port 80. It should be version 2 by default but you can try the command to make sure:
ip wccp version 2
Simon
Version is:
Version 12.4(24)T1
I am also running WCCPv2 on the router.
