Trouble configuring VPN site-to-site
Mattias13
Hello everyone. First of all I need to say that I am a beginner with Cisco devices (only been working with them for a few weeks now) Just so you guys know.
As the topic reads I am experiencing trouble configuring site to site vpn. The plan was first to create VPN between a D-link DSR500N to a Cisco ASA 5505 device but I gave that up since I never got it to work. Instead I tried to follow several different guides, cisco official book and youtube videos that show how to create VPN Cisco to Cisco since that seemed a lot easier, but I still have not got it to work. I began troubleshooting and looking for problems where it could go wrong and the only thing I could find is that I get different output when writing in the CLI.
For example if I would write:
Router(config)#Crypto isakmp enable
ERROR: % INCOMPLETE COMMAND
Router(config)#Crypto isakmp policy 10 - this command should enter Router(config-isakmp)# But instead for me this command enter Router(config-ikev1-policy)#
Why is it like that?
I would be very thankful if someone can help me with this issue.
Have a good day.
Mattias
7 Replies 7
Julio E. Moisa
Hi Mattias,
Your router should be security K9 license, if it has, please provide us the configuration on the Cisco and Dlink.
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I checked the license and it is Security Plus. Right now I need to re-configure the VPN due to a mistake which forced me to restore an old config because the router stopped working. Do you want me to run "Show running-config" and then post it here?
Best regards.
show running-config would be a good start. It would also help if you provide some description of the network topology and perhaps a diagram showing the network. It would also help if you give us a description of what you want the vpn to do, what traffic should go through the vpn. If you have done some testing it would be nice to see some test results (like can you ping from one peer address to the other peer address).
Rick
Rick
I attached a PDF file of the DLINK router config and down below you can see the config of the asa 5505.
To describe the network topology we have a office at site A and offsite storage (Site B). We want to send our backups that are encrypted through the VPN. ICMP is set to off.
Result of the command: "show running-config"
: Saved
ASA Version 9.0(2)
hostname BURouter
enable password xxxxxxxxx encrypted
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
 switchport access vlan 12
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 description BU Inside
 nameif inside
 security-level 100
 ip address 10.x.x.x 255.255.0.0
interface Vlan2
 description Incoming
 nameif outside
 security-level 0
 ip address 92.x.x.x 255.255.255.192
interface Vlan12
 shutdown
 nameif BUkund1
 security-level 100
 no ip address
ftp mode passive
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network BUProd1
 host 10.x.x.x
 description Production BU 1
object service Synology
 service tcp destination eq xxxx
 description Port in till buprod
object network outsideGW
 host 92.x.x.x
 description Quicknet GW
object network Syn1
 host 10.x.x.x
 description BU1
object network RDP
 host 10.x.x.x
 description RDP Test
object service RDP
 service tcp destination eq 3389
object service RDP-Service
 service tcp source eq 3389
object service BU_Transport_xxxx_Inside
 description BU Transport xxxx INSIDE
object service Outside_BU_Transport_xxxx
 service tcp source eq xxxx
 description Outside BU Transport xxxx
object network net-local
 subnet 10.x.x.x 255.255.255.0
 description net-local
object network net-remote
 description net-remote
access-list outside_access_in extended permit object Synology any object BUProd1
access-list outside_access_in extended permit object BU_Transport_Inside any object BUProd1
access-list outside_cryptomap extended permit ip object net-local object net-remote
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu BUkund1 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (inside,outside) dynamic interface
 nat (any,outside) static interface
nat (inside,any) after-auto source static BUProd1 BUProd1 service Outside_BU_Transport_BU_Transport_Inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 92.x.x.x 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.x.x.x 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 193.x.x.x
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 1 set ikev2 pre-shared-key *****
crypto map outside_map 1 set nat-t-disable
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 enable inside
crypto ikev2 enable outside
crypto ikev1 policy 1
 authentication pre-share
 encryption aes-256
 hash sha
 group 5
 lifetime 86400
crypto ikev1 policy 2
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd option 66 ip 10.x.x.x
dhcpd address 10.x.x.x-10.x.x.x inside
dhcpd dns 10.x.x.x interface inside
dhcpd lease 3000 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 anyconnect-essentials
group-policy GroupPolicy_193.x.x.x internal
group-policy GroupPolicy_193.x.x.x attributes
 vpn-tunnel-protocol ikev2 l2tp-ipsec
tunnel-group 193.x.x.x type ipsec-l2l
tunnel-group 193.x.x.x   general-attributes
 default-group-policy GroupPolicy_193.x.x.x
tunnel-group 193.x.x.x ipsec-attributes
 peer-id-validate nocheck
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:
: end
Mattias
Thank you for posting the configs. I understand your desire to protect sensitive information such as the public addresses of the devices. But I am puzzled at your masking of the private addresses. Showing something as 10.x.x.x does not improve your security (it is, after all, a private address and we have no way of knowing where it is or how to access it) and it presents difficulty in assessing whether the config of the peers match up appropriately.
I have looked through them and find several issues:
1) You define the subnet of the inside interface as a /16. But when you configure an object for it you change the mask to /24
pretty clearly the Dlink expects it to be /16
2) Your ASA has an address translation for any traffic originating inside and going outside. There is nothing in the config to exempt the vpn traffic from that translation.
Rick
Rick
Hey Richard, sorry if I masked the private address too much. I didn't know how much I could show/not show. If you want I can re-post it with the private addresses visible?
I changed to the correct netmask now, but I know for sure that I have put in the correct netmask before but since I have deleted and re-created the objects and vpn setup I think that might be the reason I maybe put the wrong netmask this time.
How do I enable nat exemption? On my other cisco device when I looked at VPN setup it was a little checkbox that you checked and then it was activated.
Best regards
Mattias
It is not necessary to post the config with the private addresses not masked. I point this out so that the next time you post on the forum you would think about what really needs to be protected. I recognize that there is an instinctive reaction when posting configs in public forum that we need to protect our addresses. But we should then think about what really needs to be protected.
If you have redone the configs multiple times it is quite possible that the other times did use the correct mask. I can only provide feedback on the version that got posted.
The way to do the nat exemption differs depending on whether you are using GUI/ASDM or from CLI. And the approach for nat/nat exemption is quite different depending on whether it is ASA or is IOS. For your config the nat exemption might look something like this
nat (inside,outside) source static net-local net-local destination static net-remote net-remote no-proxy-arp route-lookup
Rick
Rick
