Trouble connecting 2 1400 bridges through 1700 routers
KeithGriffith
A little background:
I have 2 1400 series bridges that I want to use to connect two networks that are about 2 miles apart. I installed the bridges and everything worked fine. I can connect through the 1400 bridges to the remote network and move data with no problem. I bought 2 1700 routers with a WIC-4ESW to connect the two networks and am having some problems.
Network A 172.23.x.x/16
1700 router F0/0 172.23.38.1
|EIGRP 100 172.20.0.0
1700 router F0/1 (WIC-4ESW)
1400 bridge 172.23.38.10
Wireless link
1400 bridge 172.20.38.10
| EIGRP 100 172.23.0.0
1700 router F0/0 172.20.38.1
Network B 172.20.x.x/16
Network B is in turn connected to 5 remote sites on different networks. Will I need to make an entry for each network in network B's router for computers on network A to access data from the other networks? I have EIGRP running on all 7 networks.
Can you see anything ovbious that I did wrong? I cant figure it out and any help would be appreciated.
