Trouble Routing VLANs through L2 and L3 Switches
TXITGUY9000
Hello All,
Having trouble trying to figure out how to get VLANs to talk to each other. I have a L2 switches 3750G and a L3 switch 3750G with IP Routing enabled. I have been testing this out in Cisco Packet Tracer, but have been trying things as well with a test environment when I can.
Here is a quick and dirty version of the network I am testing.
There are a couple VLANs
VLAN 1 - 192.168.99.0
VLAN 20 - 192.168.20.0
The PC sits on VLAN 1 and can ping any switch on it's network. The PC can also ping any VLAN on the L2 switch it is connected to. But it cannot ping the next hop on a different VLAN 192.168.20.251. (Can ping VLAN1 on the next hop though). Core is a L3 switch and the WHS under the ASA is a L3. CLI is below
I appreciate any insight.
ACCESS 3560-24PS#show run
Building configuration...
Current configuration : 1970 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
 description 2ND FLOOR OFFICE FIBER
 switchport trunk allowed vlan 1,10,20,30,98
 switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
 description User Network
 ip address 192.168.99.1 255.255.255.0
 ip helper-address 192.168.20.16
 ip helper-address 192.168.20.17
interface Vlan10
 description Internet Peering Network
 mac-address 000a.4176.dd01
 ip address 192.168.10.2 255.255.255.0
interface Vlan20
 description Server Network
 mac-address 000a.4176.dd02
 ip address 192.168.20.1 255.255.255.0
interface Vlan30
 description Camera Network
 mac-address 000a.4176.dd03
 ip address 192.168.30.1 255.255.255.0
interface Vlan98
 description Guest Network
 mac-address 000a.4176.dd04
 ip address 192.168.98.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
CORE SWITCH: show run
Current configuration : 2527 bytes
version 12.2
hostname Switch
ip routing
ip ssh version 2
ip domain-name airinnovationsllc.local
ip name-server 192.168.20.17
interface Vlan1
 ip address 192.168.99.5 255.255.255.0
interface Vlan10
 mac-address 00d0.bc1c.c601
 ip address 192.168.10.3 255.255.255.0
interface Vlan20
 mac-address 00d0.bc1c.c602
 ip address 192.168.20.251 255.255.255.0
interface Vlan30
 mac-address 00d0.bc1c.c603
 ip address 192.168.30.5 255.255.255.0
interface Vlan40
 description Phone Network
 mac-address 00d0.bc1c.c604
 ip address 192.168.40.2 255.255.255.0
interface Vlan98
 mac-address 00d0.bc1c.c605
 ip address 192.168.98.4 255.255.255.0
ip classless
ip route 192.168.20.0 255.255.255.0 192.168.20.254
ip route 192.168.99.0 255.255.255.0 192.168.99.3
ip route 192.168.30.0 255.255.255.0 192.168.30.2
ip route 192.168.98.0 255.255.255.0 192.168.98.3
line con 0
line aux 0
line vty 0 4
 login
end
WHS 3560#show run
Current configuration : 2192 bytes
version 12.2
hostname Switch
ip routing
 description Fiber Link
interface Vlan1
 ip address 192.168.99.3 255.255.255.0
interface Vlan10
 mac-address 000c.858e.d201
 ip address 192.168.10.254 255.255.255.0
interface Vlan20
 mac-address 000c.858e.d202
 ip address 192.168.20.254 255.255.255.0
interface Vlan30
 mac-address 000c.858e.d203
 ip address 192.168.30.2 255.255.255.0
interface Vlan98
 mac-address 000c.858e.d204
 ip address 192.168.98.3 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
line con 0
line aux 0
line vty 0 4
 login
end
6 Replies 6
Seb Rupik
Hi there,
Is the PC using 192.168.99.1 as its default gateway? If so you need to add:
ip routing
..to '3560-24Ps ACCESS', this will allow packets to be forwarded between the local SVIs and then routed towards an SVI on an adjacent switch.
Personally I suggest that if you want this routed access layer design, that you limit the broadcast domain of a the access VLANs to the access switch itself. Create a VLAN with a /30 subnet and use that as a point to point link between the neighbouring switch. Remove the other VLANs from the trunk and either run a dynamic routing protocol between the switches or configure static routes.
cheers,
Seb.
Can the original poster give us the output of show ip interface brief from each of the switches?
Can the original poster give us the IP address, mask, and default gateway configured on the PC?
I see interfaces configured as trunks with multiple vlans permitted and I see vlan interfaces with IP addresses. But I do not see any access interface assigned to any vlan other than vlan 1. Is that intentional?
Rick
Rick
@Seb Rupik
Thanks for the info. I was under the assumption if the Default gateway of the PC was the Layer 2 VLAN on the access, it would route the packet to the next hop and then route to the appropriate vlan it is trying to send a packet to. Adding the Default gateway of the PC to CORE allowed me to route packets to any VLAN like you suggested.
Also, for what your suggesting, the ACCESS switch would need to be in LAYER3 routing mode?
You could use the access switch SVI at the gateway, but you need to enable ip routing on it. That is why using the CORE SVI as the gateway works.
For the routed access layer solution to work, you will need to firstly enable ip routing and then add routes to the routing table either via IGP or statically. Arguably the routed access design would work fine with your current trunked VLAN configuration, but to be correct you will want to remove all existing VLANs from the trunk link and create a new /30 subnet to be used for IGP peering and transit traffic between itself and the upstream switch.
cheers,
Seb.
@Seb Rupik
I want to make sure I understand this correctly. But your suggesting I create a new VLAN and subnet purely for the trunk between the core and access. Then route all traffic through that new vlan? What benefit does this provide? I though having IP Routing enabled (InterVLAN) takes away the need for static and dynamic routing protocols. So that would seem redundant correct?
I only suggested a routed access design as that is what your original configuration appeared to be trying to achieve, ie, you had SVIs for all of the VLANs present on the access switch.
A 'standard' 2/3 tier design keeps the Layer3 boundary off the access layer. This is achieved by not having any SVIs present (with the exception for management), instead VLANs exist only at Layer 2 and all traffic which needs to be routed is sent via Layer2 trunk links upstream to the distribution or core layer.
Regarding the benefits of a routed access layer, take a look at this document:
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/resilient-services-solution-campus-network/net_qanda0900aecd8045965a.html
cheers,
Seb.
