Trouble with Ethernet WAN
MylesselyM
Hi! This is my first post here. Thanks to Cisco for providing this valuable resource. I'm primarily a Unix system administrator, but I wear many hats do to the small size of the company I'm currently working for. In other words, we don't have a dedicated network engineer.
We recently turned up an AT&T Ethernet WAN circuit between our two data centers (one in Boston, the other in New Jersey). The circuit is supposed to provide 150 Mbit/s. Testing with iperf, I see the expected throughput running from New Jersey to Boston (>100 Mbit/s), but only about one fifth what is expected running from Boston to New Jersey (30 Mbit/s). There are no errors on the Cisco 3560 switches at either end. The odd thing is, if I run 5 iperf clients simultaneously in Boston, each will show just over 20 Mbit/s, which means just about 100 Mbit/s total.
Any ideas what might be wrong? Configuration snippets and iperf test results can be found at the end of the post. Thanks in advance for any suggestions.
Best wishes,
Myles
Boston Switch:
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
cisco WS-C3560G-24TS (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC1028Z3DD
#show interfaces gi0/27 status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/27                       connected    26           full   1000 1000BaseLX SFP
GigabitEthernet0/27 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0018.b954.bd1b (bia 0018.b954.bd1b)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:34, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     119154244 packets input, 47574275052 bytes, 0 no buffer
     Received 7261 broadcasts (7234 multicasts)
     0 watchdog, 7234 multicast, 0 pause input
     189612796 packets output, 266293462185 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Boston Test Host:
# ifconfig eth3
eth3      Link encap:Ethernet  HWaddr 00:24:81:7C:79:43
          inet addr:192.168.26.4  Bcast:192.168.26.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1128881484 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5901215833 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:126526667110 (117.8 GiB)  TX bytes:8700597434340 (7.9 TiB)
          Interrupt:185 Memory:fdea0000-fdec0000
# ethtool eth3
Settings for eth3:
        Supported ports: [ TP ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised auto-negotiation: Yes
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0x00000001 (1)
        Link detected: yes
Single iperf client running in Boston:
# iperf -c 192.168.26.5 -n 1073741824 -m
Client connecting to 192.168.26.5, TCP port 5001
TCP window size: 16.0 KByte (default)
[  3] local 192.168.26.4 port 36403 connected with 192.168.26.5 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-278.6 sec  1.00 GBytes  30.8 Mbits/sec
[  3] MSS size 1448 bytes (MTU 1500 bytes, ethernet)
Five iperf clients running simultaneously in Boston:
[  3] local 192.168.26.4 port 54037 connected with 192.168.26.5 port 5001
[  3]  0.0-81.5 sec   205 MBytes  21.1 Mbits/sec
[  3] local 192.168.26.4 port 54038 connected with 192.168.26.5 port 5001
[  3]  0.0-83.4 sec   205 MBytes  20.6 Mbits/sec
[  3] local 192.168.26.4 port 54039 connected with 192.168.26.5 port 5001
[  3]  0.0-85.7 sec   205 MBytes  20.0 Mbits/sec
[  3] local 192.168.26.4 port 54040 connected with 192.168.26.5 port 5001
[  3]  0.0-85.7 sec   205 MBytes  20.1 Mbits/sec
[  3] local 192.168.26.4 port 54041 connected with 192.168.26.5 port 5001
[  3]  0.0-83.0 sec   205 MBytes  20.7 Mbits/sec
New Jersey Switch:
cisco WS-C3560G-48TS (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1047Z59G
#show interfaces gi0/52 status
Gi0/52                       connected    26           full   1000 1000BaseLX SFP
GigabitEthernet0/52 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001a.6c4b.08b4 (bia 001a.6c4b.08b4)
  Keepalive not set
  Last input 00:00:01, output 00:00:48, output hang never
     188270859 packets input, 264260280083 bytes, 0 no buffer
     Received 224109 broadcasts (223448 multicasts)
     0 watchdog, 223448 multicast, 0 pause input
     119392994 packets output, 47761060680 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
New Jersey Test Host:
# ifconfig eth3
eth3      Link encap:Ethernet  HWaddr 00:15:17:16:DF:3B
          inet addr:192.168.26.5  Bcast:192.168.26.255  Mask:255.255.255.0
          RX packets:188140437 errors:0 dropped:0 overruns:0 frame:0
          TX packets:119225785 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:263306036792 (245.2 GiB)  TX bytes:46892828314 (43.6 GiB)
          Interrupt:177 Memory:fdfa0000-fdfc0000
# ethtool eth3
Settings for eth3:
                                1000baseT/Full
                                1000baseT/Full
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 1
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
Single iperf client running in New Jersey:
# iperf -c 192.168.26.4 -n 1073741824 -m
Client connecting to 192.168.26.4, TCP port 5001
[  3] local 192.168.26.5 port 13424 connected with 192.168.26.4 port 5001
[  3]  0.0-77.7 sec  1.00 GBytes   111 Mbits/sec
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Might be lost packets in the MetroE providers cloud.
Might be one set of clients RWIN isn't large enough for th bandwidth delay product.
I think frames are being dropped in the "cloud". I tried testing with iperf using UDP instead of TCP, setting a target bandwidth of roughly 140 Mbit/s. Quite a few datagrams were dropped.
# iperf -c 192.168.26.5 -u -b 140000000 -t 60 -i 6
Client connecting to 192.168.26.5, UDP port 5001
Sending 1470 byte datagrams
UDP buffer size:  126 KByte (default)
[  3] local 192.168.26.4 port 34346 connected with 192.168.26.5 port 5001
[  3]  0.0- 6.0 sec   100 MBytes   140 Mbits/sec
[  3]  6.0-12.0 sec   100 MBytes   140 Mbits/sec
[  3] 12.0-18.0 sec   100 MBytes   140 Mbits/sec
[  3] 18.0-24.0 sec   100 MBytes   140 Mbits/sec
[  3] 24.0-30.0 sec   100 MBytes   140 Mbits/sec
[  3] 30.0-36.0 sec   100 MBytes   140 Mbits/sec
[  3] 36.0-42.0 sec   100 MBytes   140 Mbits/sec
[  3] 42.0-48.0 sec   100 MBytes   140 Mbits/sec
[  3] 48.0-54.0 sec   100 MBytes   140 Mbits/sec
[  3] 54.0-60.0 sec   100 MBytes   140 Mbits/sec
[  3]  0.0-60.0 sec  1001 MBytes   140 Mbits/sec
[  3] Sent 714197 datagrams
[  3] Server Report:
[  3]  0.0-60.0 sec  1000 MBytes   140 Mbits/sec   0.168 ms  954/714196 (0.13%)
[  3]  0.0-60.0 sec  1 datagrams received out-of-order
Leo Laohoo
Who's doing packet shaping of your WAN traffic?
Any shaping or QoS is being done by AT&T. To us, it's just Ethernet.
Myles
MylesselyM
AT&T shed some light on this for me, and it is now performing satisfactorily in both directions.
At each end, the 1 Gbit/s ethernet is multiplexed on 3 50 Mbit/s SONET STS channels (this is how 150 Mbit/s is achieved). The frames that wouldn't fit down the 3 STS channels were being discarded.
I added the following to the switch ports at both ends:
srr-queue bandwidth limit 14
(14% of 1 Gbit/s is roughly 140 Mbit/s)
Best wishes,
Myles
