Route map and NAT config not working with 2 DSL circuits
rgaleana06
I have a 2921 router connected to 2 DSL circuits - DSL1 on gig0/1 and DSL2 on gig0/2.
I am using a route map to force individual hosts to use DSL2 for internet traffic.  I'm using a standard NAT overload statement with ACL to NAT on both DSL interfaces.
All traffic to DSL1 is working as expected.  I see packets matching route-map DSL and being routed to DSL2, however I'm not seeing NAT translations for DSL2 interface.
Here's the config -
interface GigabitEthernet0/0.50
description Server VLAN
encapsulation dot1Q 50
ip address 10.5.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip policy route-map DSL
interface GigabitEthernet0/1
description DSL1
ip address 71.189.199.201 255.0.0.0
ip nat outside
duplex full
speed auto
interface GigabitEthernet0/2
description DSL2
ip address 173.60.176.18 255.255.255.0
ip nat outside
duplex auto
speed auto
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip nat inside source list 101 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 71.189.199.1
ip access-list extended Test
deny   ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255
deny   ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255
deny   ip 10.5.0.0 0.0.255.255 172.16.0.0 0.15.255.255
permit ip host 10.5.0.11 any
access-list 100 deny   ip 192.168.22.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 100 deny   ip 192.168.22.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 100 deny   ip 192.168.22.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 100 permit ip 192.168.22.0 0.0.0.255 any
access-list 100 deny   ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 deny   ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 100 deny   ip 10.5.0.0 0.0.255.255 172.16.0.0 0.15.255.255
access-list 100 permit ip 10.5.0.0 0.0.255.255 any
access-list 101 deny   ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 101 deny   ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 101 deny   ip 10.5.0.0 0.0.255.255 172.16.0.0 0.15.255.255
access-list 101 permit ip 10.5.0.0 0.0.255.255 any
route-map DSL permit 60
match ip address Test
set ip next-hop 173.60.176.1 (default gateway for DSL2)
Show commands -
HUE-GW-01#show ip access-list
Extended IP access list 100
    10 deny ip 192.168.22.0 0.0.0.255 192.168.0.0 0.0.255.255
    20 deny ip 192.168.22.0 0.0.0.255 10.0.0.0 0.255.255.255
    30 deny ip 192.168.22.0 0.0.0.255 172.16.0.0 0.15.255.255
    40 permit ip 192.168.22.0 0.0.0.255 any
    50 deny ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255
    60 deny ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255
    70 deny ip 10.5.0.0 0.0.255.255 172.16.0.0 0.15.255.255
    80 permit ip 10.5.0.0 0.0.255.255 any (505 matches)
Extended IP access list 101
    10 deny ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255
    20 deny ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255
    30 deny ip 10.5.0.0 0.0.255.255 172.16.0.0 0.15.255.255
    40 permit ip 10.5.0.0 0.0.255.255 any
Extended IP access list Test
    10 deny ip 10.5.0.0 0.0.255.255 192.168.0.0 0.0.255.255 (2854 matches)
    20 deny ip 10.5.0.0 0.0.255.255 10.0.0.0 0.255.255.255 (4239 matches)
    40 permit ip host 10.5.0.11 any (201 matches)
HUE-GW-01#show route-map
route-map DSL, permit, sequence 60
  Match clauses:
    ip address (access-lists): Test
  Set clauses:
  Policy routing matches: 184 packets, 14947 bytes
Any thoughts?  Thanks in advance!
Your access-list 100 matches the traffic 10.5.x.x which you want to NAT to DSL2, where as access-list 100 is overloaded(pat) to interface DSL1 interface.
Remove those ace's from access-list 100 so that they ll match overload statement for DSL2 interface.
Hope this helps
The problem with this solution is that it would not allow traffic from 10.5.0.0 to be translated if it is going out Gig 0/1. And most of the traffic from 10.5.0.0 would use Gig 0/1 given the config that was posted.
The better solution is to re-write the logic for address translation. Instead of just using access lists to control the NAT use route maps to control the NAT. In the route map you can have a match statement to match the interface and a second match statement to match the access list. That way access list 100 is used only with Gig 0/1 and access list 101 is used only with Gig 0/2. This should solve your problem.
Rick
Rick
I would like to add to my previous post as I overlooked the route-map and. Access-list TEST.
There is a route-map matching traffic for a host in access-list TEST to set next hop as dsl2. But that matching is not correct, use the network 10.5.0.0 instead so that it will match the access-list TEST and in turn will nat it towards dsl2.
LukaszTJB
Could you post a 'show ip nat stat'. I assume that your nat configuration isn't correct. To use multiple outside nat interfaces you have to use route-maps in the ip nat configuration.
Ip nat inside source route-map interface gig0/2 overload
The route map should look like
Route-map dsl1-wan permit 10
Match interface gig0/2
Match ip address
Sent from Cisco Technical Support Android App
