Trouble with upgrade IOS on 7206vxr
Rick Morris
Level 6
Level 6
I am not sure what I am doing wrong so hopefully someone will see my bonehead mistake.
Here is the issue:
MONEXTR01(boot)#copy tftp bootflash:
Address or name of remote host []? 10.1.1.240
Source filename []? c7200-adventerprisek9-mz.124-24.T1.bin
Destination filename [c7200-adventerprisek9-mz.124-24.T1.bin]?
Accessing tftp://10.1.1.240/c7200-adventerprisek9-mz.124-24.T1.bin...
%Warning: File not a valid executable for this system
Abort Copy? [confirm]
Here is the sh ver:
MONEXTR01(boot)#sh ver
Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 19-Dec-06 16:07 by alnguyen
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
MONEXTR01 uptime is 10 minutes
System returned to ROM by reload at 02:50:20 UTC Sat Feb 19 2000
System image file is "bootflash:c7200p-kboot-mz.124-4.XD5.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID 26822998
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.6
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 100 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
1 Serial interface
2045K bytes of NVRAM.
254464K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
MONEXTR01(boot)#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. image D9C0D081 80F474 29 7926772 Jan 18 2000 23:50:41 +00:00 c7200p-kboot-mz.124-4.XD5.bin
57609100 bytes available (7926900 bytes used)
What am I missing?
Jerry Ye
You download the wrong image. You have a NPE-G2. The image name is c7200p-adventerprisek9-mz.124-24.T1.bin.
There is a p after the c7200.
HTH,
jerry
Giuseppe Larosa
Hello Rick,
the image could be for an older processor type notice that your current image has name:
you need an image that starts with C7200p
see on one my c7200 with NPE-G2
sh ver | inc image
System image file is "disk2:c7200p-advsecurityk9-mz.124-20.T.bin"
sh ver | inc NPE
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
hope to help
Giuseppe
Jerry Ye
HTH,
jerry
Thanks G and Jerry!
I found what I did wrong by your postings. When I downloaded the IOS I did not see under the links to choose which file you want another link for the NPE, kind of buried since my IE window was not full size. We will call this a Web-Design flaw since, IMHO, should be a direct link before you get to this point for the NPE.
Thanks again!
Rick
