Troubleshooting
Ravi Pande
You have 5 servers with ip address A,B,C,D and E.
These 5 servers are connected to a load balancer.
Load balancer is connected to router ,
ip address of load balancer interface is Y towards router and ip address of router interface pointing towards load balancer is X.
Now I have advertised to the world to reach suppose cisco.com the ip address is E.
And i have wrongly configured the ip address here i.e Y instead of E and vice versa.
The problem is traffice is going to server with ip address E only.
So find 4-5 solutions so that other 4 servers also can be used and note: no ip address can be change this is the scenario now.
I am attaching the image for your reference.
Thank You.
chrihussey
So you can't change the physical IP addresses and you mixed up the IPs between the load balancer and server E.
Why not just make the DNS change so that it points to the load balancer? May take some time to propagate, but in time it will work the way you want.
You cant make the dns change.This question was asked in an interview.
