TRUNKING CONFUSION !!
seamus00111
What is the default trunking mode on switches?
I appreciate this might be a no brainer for most of you, but please bare with me!
None of the switches below have been configured
This is the output from a switch running iOS (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
ESW1#show int switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: none
Protected: false
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
This is the default output from a switch running C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(37)SE1, RELEASE SOFTWARE (fc1)
Switch>enable
Switch#show int switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: All
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
This is the  output from a switch running C2960 Software (C2960-LANBASE-M), Version 12.2(25)FX, RELEASE SOFTWARE (fc1)
Switch>enable
Switchport: Enabled
Voice VLAN: none
Protected: false
Here is a quote from the book CISCO OFFICIAL CERT GUIDE: CCNP Routing & Switching SWITCH 300-115
"In the switchport mode command, you can set the trunking mode to any of the
following:
■ trunk...........
■ dynamic desirable (the default):................
■ dynamic auto................"
Can anybody shed some light on this question.
thanks
0 Replies 0
