Trusting Service Providers MPLS VPN
Aaron Resler
In your experience, do SP customers (i.e. Banks, Retail, Gov't etc) trust the MPLS VPN service? So by that, I am asking if it is common for SP customers to deploy encrypted overlay solutions (eg IPSEC) for lack of trust of the MPLS VPN? Or, do they trust the implicit security offered by the MPLS VPN service, and send clear text.
I assume the answer isn't black and white, so looking for opinion and experience.
John Blakley
Aaron,
I would assume that any high risk business that deals with secrets of any sort would have some sort of encryption between their locations. You're correct in that you can't trust the service provider to not leak routes accidentally to other vrfs, so it would be in that company's best interest to add another layer of protection.
HTH,
John
HTH, John *** Please rate all useful posts ***
vmiller
Level 7
Level 7
Aaron,
I was part of a team that deployed an nationwide MPLS VPN for a financial institution. We did not use any encrypted overlay, but or primary app (banking) used SSH. Leaking routes are one thing, leaking routes and somehow using the same VRF.... never heard of it, but that doesn't mean it can't happen.
Nandan Mathure
Hi Aaron,
i have seen 2 financial insitutions (mid size) that do not have any ipsec vpn for MPLS. As VMILLER said applications communicating over the WAN themselvez encrypt and send the data which is important.
But in your case if you think that data is extremely important to be kept confidential then go for IPsec over MPLS.
Nandan Mathure
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If the information is sensitive enough that it should be "secret", then as the other posters have noted, one should use some form of end-to-end encryption.  For more "routine" business traffic, MPLS VPN isolation is often "good enough" (as is ATM or Frame-Relay PVCs).
