trying to connect to internet with pat
chr6is000
hey guys thanks for looking at my post, i have been setting up internal networks nothing hooked up to the net, but now i want to hook up to the net and need some guidence. my set-up so far is just fairly simple to test for connectivity.
i took out my fios router and took the main cable and plugged it into my 2010xm router's 1t dsu/csu...
i looked up in windows ipconfig to find the ip address that was being used......192.168.1.3
i then set that address on the serial interface
i then sutup vlan 1 and vlan 2 on the fastethernet 0/0, i am using the vlan 2 and setup the private address as 192.168.10.17 255.255.255.248
i did a:
router eigrp 10
network 192.168.1.0    0.0.0.255
network 192.168.10.0    0.0.0.255
no auto-sum
i then connected the router to a switch and made the int vlan 2's ip address 192.168.10.18 and did a no sh
set the ports for trunking and access vlan 2
i set my computer's network as ip address 192.168.10.19, mask 255.255.255.248, default 192.168.10.17
all of this for internetworing was operational i could ping everything.................................................
no i set-up pat on the router:
ip nat pool connection 192.168.1.3 192.168.1.3 netmask 255.255.255.0
access-list 1 permit 192.168.10.0 0.0.0.255
ip nat inside source list 1 pool connection overload
int s0/0
ip nat outside
int fa 0/0.2
ip nat inside
that is all i have set-up, question is-----
1. is the main internet cable suppose to be plugged into that port or do i need some other device?
2. i know the internal network works but am i missing anything like a dhcp server or somethinng?
3rd thanks
Richard Burts
1) If your main internet cable was connected to a fios router then it will not work plugged into a router serial T1 interface.
2) dhcp is nice to have but is not a requirement to establish successful networking.
Rick
Rick
thanks for the reply, i disconnected the fios and took the main rj45 cable and plugged it into the wan port of the router, could you explain why it would not work im not sure why.
i set up the wan interface with 192.168.1.1    255.255.255.0
i set nat with a pool from 192.168.1.1 192.168.1.1
i set the fa port as 192.168.10.1   255.255.255.0
crossover cable to the pc, set address on pc to 192.168.10.2, default 192.168.10.1, mask 255.255.255.0
while on the router i can ping the WAN int, i did a sh int s0/0 and it said it was down, and line protocol is down
here is a sh run:
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
ip nat outside
no fair-queue
router eigrp 10
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat pool connection 192.168.1.1 192.168.1.1 netmask 255.255.255.0
control-plane
line con 0
line aux 0
line vty 0 4
end
