Trying to influence BGP routes with 2 different ISPs
JP Babiera
Level 4
Level 4
Hi Everyone,
I'm trying to figure out the best way to do this.  Basically, I have a router that's peering with 2 different providers using BGP.  I want to make sure that certain network follow a specific provider as a primary, but can also use the second provider as a backup.
(see image attached)
I am provided a /23 address that I will be advertising to the BGP neighbors.  I would like a /24 intended for PC-A go down ISP-A as primary, and ISP-B as secondary; but also at the same time have a /24 intended for PC-B go down ISP-B as primary and ISP-A as secondary.
I'm considering using route-maps
Is this something that I would want to use?
ip access-list standard PC_A
permit 1.1.0.0 0.0.0.255
ip access-list standard PC_B
permit 1.1.1.0 0.0.0.255
route-map RMAP_A_IN permit 10
    match ip address PC-A
        set local-preference 200
route-map RMAP_A_IN permit 20
    match ip address PC_A
        set local-preference 100
route-map RMAP_A_IN permit 30
        set local-preference 50
route-map RMAP_B_IN permit 10
     match ip address PC_B
route-map RMAP_B_IN permit 20
route-map RMAP_B_IN permit 30
router bgp 12345
    network 1.1.0.0
    network 1.1.1.0
    neighbor ISP-A remote-as 5555
    neighbor ISP-A route-map RMAP_A_IN in
    neighbor ISP-B remote-as 7777
    neighbor ISB-B route-map RMAP_B_IN in
cyoonpeacecorps
Seems like you have a single router with two ISPs and also you are talking about BGP configuration for inbound traffic Only.
How about outbound traffic?
In terms of inbound traffic control (mainly ISPs), I recommended use their BGP community strings.
It is not only efficient nor effective. Your BGP attribute might not be working within ISP's network.
Also, your configuration would be a lot simpler. Check below link for easy to understand
http://showipbgp.com/bgp-configurations/cisco.html
I hope it is informative for you
C
