Trying to upgrade 4506 IOS Image but failed...
cindylee27
Hi Experts,
I have tried to upgrade the new IOS Image of 4506 but failed.. well, the IOS image already tftp inside to this switch. What I have done is as below:
1) Tftp to the switch
2) boot system flash:(IOS Image.bin)
3) reload
But seems like after reload, the IOS is still the old one.
Where do I go missing?
Thanks in advanced.
ankbhasi
Hi Cindy,
Can you paste the output of "sh version" and "dir bootflash:"? Can you check if config reg value is set to 0x2102 from show version?
Ankur
Thanks Ankur. The problem solved..
Got to go to bootup, rommon> , then I managed to do upgrade from there..
Thanks again for your reply. :)
