ttcp/iperf c3650
Bthene
While trying to accomplish branch bandwith testing I noticed
the ttcp function seems to have been removed in the newer 3650 platform,
can't find any other documented way of accomplish this function on a 3650 switch,
ideas ?
https://en.wikipedia.org/wiki/Ttcp
Bthene
Solved, tried on a 3850 IPservices and it worked as intended, the 3650 only had IPbase.
also verified it working on a 3650 IPservices
Bthene
In which version of code did you test it?
What's the specific sintax of the command you're using? ttcp transmit and ttcp receive EXEC mode command?
Thank you!
