Tunel gre con ipsec
Int_19
Hola buen día.
Estoy estableciendo un tunel gre con ipsec.
Quiero agregar una ACL a la interfaz tunel, pero cuando agrego el crypto map a la interfaz tunnel se cae la vpn.
y si agrego el ACL a las interfaces fisicas no realizan el filtrado de las ip´s.
Como podría solucionar esto?
Agrego sh run de los routers
Router 1:
Building configuration...
Current configuration : 1753 bytes
! Last configuration change at 15:28:14 UTC Wed Oct 7 2020
version 15.4
no service pad
hostname
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO881-SEC-K9 sn FTX1804817N
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 14
lifetime 3600
crypto isakmp key 123 address [a] no-xauth
crypto ipsec transform-set AES256-SHA512 esp-aes 256 esp-sha512-hmac
mode transport
crypto ipsec profile TO-MTY
set transform-set AES256-SHA512
set pfs group14
crypto map vpn-map 50 ipsec-isakmp
set peer [a]
set pfs group14
match address VPN-MTY
interface Tunnel0
tunnel source [b]
tunnel destination [a]
tunnel protection ipsec profile TO-MTY
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address [b] mask
ip access-group VPN-MTY in
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.1.0 255.255.255.0 192.168.1.2
ip access-list extended VPN-MTY
permit ip 10.26.0.0 0.0.255.255 10.24.0.0 0.0.255.255
control-plane
vstack
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
end
Router 2:
Current configuration : 1986 bytes
version 15.2
hostname
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FGL180321A3
redundancy
encr aes 256
group 14
lifetime 3600
crypto isakmp key 123 address [b] no-xauth
mode transport
crypto ipsec profile TO-CEL
set pfs group14
set peer [b]
set pfs group14
match address VPN-CEL
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
tunnel source [a]
tunnel destination [b]
tunnel protection ipsec profile TO-CEL
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
no ip address
no ip address
no ip address
no ip address
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
ip address [a] mask
ip access-group VPN-CEL in
duplex auto
speed auto
interface Vlan1
no ip address
no ip http server
ip route 192.168.1.0 255.255.255.0 192.168.1.1
ip access-list extended VPN-CEL
permit ip 10.24.0.0 0.0.255.255 10.26.0.0 0.0.255.255
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Hola,
no puedo ver ningun red local (LAN) en los routers. La ACL VPN-MTY es para definir el tráfico cifrado, normalmente el tráfico entre los dos redes locales. ¿Cuáles son los redes locales?
GRE tunnel need only IPSec profile why you config IPSec map?
