01-25-2016 05:10 AM - edited 03-05-2019 03:11 AM
Is it possible de tune the timers for (whether it's on NX-OS or IOS/XE) ?
- LACP
- UDLD
Mehdi
Solved! Go to Solution.
01-25-2016 08:24 PM
Dear Mehdi
Yes it can be done
Check this article from Cisco
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_basic.html#pgfId-2266337
You can change the LACP timer rate to modify the duration of the LACP timeout. Use the lacp rate command to set the rate at which LACP control packets are sent to an LACP-supported interface. You can change the timeout rate from the default rate (30 seconds) to the fast rate (1 second). This command is supported only on LACP-enabled interfaces. To configure the LACP fast time rate, see Configuring the LACP Fast Timer Rate.
Cheers
Yasir
01-25-2016 08:24 PM
Dear Mehdi
Yes it can be done
Cheers
Yasir
