Tunnel GRE AND IPSEC
bruno.trombim
Hi guys,
i am facing a problem since we decided to enable ipsec over our Mpls tunnel, our enviroment already have Ipsec enabled in our backup link that uses wire internet, the problem came up when try to enable it over the Tunnel that cross our mpls to our branchs, the connection seems to match because the status shows active but in one side the tunnel do not get up, in attach are 4 files with our configuration and some tests enviroments please if need any further details to help let me know.
best regards,
Support07
please show us the output of show crypto session remote X.X.X.X detail , on both router
Support07
Hi Dear,
thanks for your interest to help, instead i didnt need to go further to resolve the problem, as both side was showing active ipsec and even package exchanging so i just remove the tunnel and added a new one to fix it.
thanks !!!!
