Tunnel interface ip mtu vs mpls mtu commands
kevin.r719
hey,
so if you have an encrypted tunnel and the tunnel ip mtu is 1400, how do you set the
mpls mtu
command if you expect 2 labels max? do you make it the same as the tunnel mtu? Or how do these commands work exactly?
M02@rt37
Hello @kevin.r719
Calculate the MPLS MTU by subtracting the MPLS label stack overhead from the IP MTU. So, if IP MTU is 1400 and the MPLS overhead for two labels is, i.e.8 bytes, then the MPLS MTU might be set to 1392.
Best regards
6 Replies 6
M02@rt37
Hello @kevin.r719
Best regards
Thanks. I can't really find the documentation on this so essentially it's the max mtu before the mpls labels
@kevin.r719
Yes, the MPLS MTU is essentially the maximum size of the packet before MPLS labels are added. In your case, with a tunnel IP MTU of 1400 and considering 2 MPLS labels with an overhead of 8 bytes, the MPLS MTU would be 1392. This ensures that the packets can accommodate the MPLS label information within the specified maximum size.
Best regards
I will test this case in lab if you want.
MHM
that would be cool. constraints
the ip mtu is 1400
using ipsec gre's
the maximum labels 2
Yes I prefer lab for some case.
I Will run lab and update you tonight
MHM
