How to insert new entry to the existing prefix-set on NCS 500 router?
Herman2018
Level 3
Level 3
Hello, can anyone can please advise how to insert new entries to an existing prefix-set on NCS 500 router? prefix-set doesn't use seq, don't know how to insert. Please advise, thanks.
6 Replies 6
M02@rt37
Hello @Herman2018
rewrite the entire PL with your new lines and commit.
Best regards
Thanks M02@rt37  for your kind advice. the solution looks terrible for a long prefix-set, and it may cause network outage during change if there is some human errors.
@Herman2018
NCS are IOS-XR? you have a
commit changes
command no ? The modifications could be verify before commit.
Best regards
thanks @RoadRunner4k M02@rt37 , yes, NCS os is IOS-XR. v7.3.2
You're welcome @Herman2018
Best regards
